Sounds like it may have gotten a bit hot and vented or may have been overfull of electrolyte. Get an Optima Red or Yellow top battery and you'll bever see that again or have terminal corrosion. Otherwise, just keep clean and check periodically as wet-type batteries are constantly venting gas and sometimes liquid. That's part of what causes corrosion of the terminals and nearby metal objects.
