Page 1 of 3 1 2 3 LastLast
Results 1 to 15 of 40
Thread: How many owners have noticed engine vibration (around 2500 rpms)?
89Vette How many owners have noticed... 05/26/2010, 07:55 PM
RamAirZ I have the same thing, I feel... 05/26/2010, 08:36 PM
VX crazy i have so much vibration that... 05/26/2010, 08:36 PM
SuperBoomTurbo Sounds like a cheap date! 05/27/2010, 06:03 PM
SuperBoomTurbo For the actual post:... 05/27/2010, 06:22 PM
RamAirZ lol, saves money on toys huh 05/26/2010, 08:47 PM
89Vette Is the crank pulley... 05/26/2010, 09:24 PM
RamAirZ I remember someone talking... 05/26/2010, 09:43 PM
Triathlete Seems to me that if there was... 05/26/2010, 09:54 PM
89Vette Thanks! (BTW: Who's Jerry?)... 05/26/2010, 10:24 PM
SlowPro48 Then don't buy a vehicle that... 05/27/2010, 12:31 PM
RamAirZ I'm thinking it's more engine... 05/26/2010, 10:05 PM
RamAirZ Jerry is like the GOD of the... 05/26/2010, 11:10 PM
89Vette :thumbup: 05/27/2010, 06:53 AM
MSHardeman Glad to hear that it's not... 05/27/2010, 07:32 AM
RamAirZ Here is a response from... 05/27/2010, 07:58 AM
RamAirZ Like I said, for me it's... 05/27/2010, 12:40 PM
Triathlete I had the pleasure of meeting... 05/27/2010, 01:07 PM
RamAirZ Ya he's an awesome guy! His... 05/27/2010, 01:12 PM
RamAirZ Putting it in drive with your... 05/27/2010, 06:47 PM
SuperBoomTurbo Off topic, but do you... 05/27/2010, 07:58 PM
RamAirZ Well alot of it has to do... 05/27/2010, 11:49 PM
89Vette Thanks. I note this... 05/27/2010, 11:59 PM
RamAirZ Well NEED is a term used... 05/28/2010, 12:10 AM
deermagnet I have an Isuzu tech training... 05/28/2010, 06:53 AM
SlowPro48 Haha! Mark your VX has been... 05/29/2010, 11:52 AM
89Vette Thanks for the reply! This... 05/29/2010, 12:34 PM
RamAirZ Well also a vibration to one... 05/28/2010, 09:38 AM
89Vette I agree this is a DIFFICULT... 05/28/2010, 01:03 PM
89Vette Maybe this 6VE1 really isn't... 05/28/2010, 09:20 PM
technocoy I think this is a car that... 05/28/2010, 10:23 PM
RamAirZ I avg. about 17 with my lift... 05/30/2010, 12:55 PM
    Feb 2010
    2001 VX 1320 -- Ebony
    Thanked: 19
    The most common cause I can think of for this is an out-of-balanced motor, bad motor mount, and/or failing harmonic balancer.
    How many of you have noticed your VX having an engine vibration that's most prominent about 2500rpms? (Hint: If it's really the motor, you'd be able to feel the same symptom when stopped and in PARK!)
    Thanks!
    Gregg
    P.S. Bonus points go to anyone who's seen/solved the problem. (There's a VX I'd like to buy, but with a vibration and the 3.5L black-cloud, I'm hesitant. OTOH, engine vibrations aren't always the short-block.)
    Is there a TSB for this?
    Apr 2010
    I have the same thing, I feel it even more now that I fixed my tranny mount (I had NO bolts holding the mount to the tranny lol). I'm not toooo worried about it as it has oil, runs smooth, just has a bit of a vibration, which could just be engine design for some cars (some engines just vibrate, even in perfect running condition). I looked at it this way, no check engine lights, no other symptoms, I'm ok with it lol. I've driven a small block 350 with solid valvetrain and solid motor mounts with a 4K stall converter as an everyday driver before, so this is plush for me lol.
    i have so much vibration that I cant stop driving it around......especially since Moab.....vibration AND grinding!
    Mar 2010
    1999 Hi Yo! Silver Astral #1275
    You must be a nurse, right?
    "Forum signatures are for fools." ~Anonymous Fool
    Mar 2010
    For the actual post: especially in the body on frame cars of japanese origin, the motor mount Spacers were made of soft squishy rubber that all came from the same supplier. These are not like the indestructible urethane aftermarket type. After lots of hard revving or even just years of weather exposure (high heat, road salt, etc) they break down like wiper blades.
    With that in mind, its easy to test. With the engine off, go push on it side to side and see how much wiggle you get. With the engine on, leave it in park (of course) and blip the throttle body through short rev ranges. Bet it moves a lot if your mounts are trashed! As the rpm's climb, the engine movement settles down as all the torque presses the engine down on the mounts.
    I drove a '90 240sx for years with this same issue and didn't notice a problem mechanically til I swapped the transmission. It'd shake and shimmy at stoplights like it had a blown hemi under the hood, resulting in the occasional 'seat wood'. (TMI!!) though the lady passenger of the time didn't seem to mind.
    Now if your motor vibrates when doing highway speed like something is about to explode under there (ie under load), that sounds quite a bit more complicated, and in which case, you will soon see money flowing down the street behind you in the form of engine internals becoming externals...
    Apr 2010
    Feb 2010
    Thanked: 19
    Is the crank pulley integrated with the balancer? Have these been known to fail? How about motor mount failures?
    Are these internal/externally balanced motors?
    Apr 2010
    I remember someone talking about the 3.2's having balancer issues (balancer coming apart) awhile back. I'll ask Jerry for ya. I'm pretty sure the puller and balancer are one
    Seems to me that if there was a balance issue that it would be worse as the RPMs increased and not specific to just the 2500 RPM area.
    Is the engine running smooth otherwise?
    Feb 2010
    Thanked: 19
    Quote Originally Posted by RamAirZ
    I remember someone talking about the 3.2's having balancer issues (balancer coming apart) awhile back. I'll ask Jerry for ya. I'm pretty sure the puller and balancer are one.
    Thanks! (BTW: Who's Jerry?) FWIW, I've also heard of balancer issues in whole companies. Pioneer balancers have a bad rap after lots of failures from 2003-2008. Some even say it's still going on. (Don't know what "brand" Isuzu uses.)
    Edit: If Jerry's a tech, could you (or I) ask him how to determine if the balancer (or mounts) are failing?
    The engine runs VERY smooth below 2k rpms. There is no miss. Vibration does continue to exist above 2500 rpms but it seems slightly less pronounced. When I let off the gas, there is a slight stumble/vibration as it passes below 2k rpms. It almost feels like a miss. OTOH, maybe it could be the balancer "settling" back into a slower rythm. (Or if caused by a mount, maybe it's torque rebound contact/vibration.)
    This could be described as harmonic vibration. The level is similar to a lawn motor above 2200 rpms. But I expect an automobile motor to feel smooth until redline.
    Jul 2004
    2000, Kaiser Silver, 0196
    Quote Originally Posted by 89Vette View Post
    Then don't buy a vehicle that has a 75 degree V6 with no balance shaft! The 6VE1 is always going to feel a little uncivilized...
    Feb 2010
    Thanked: 19
    Quote Originally Posted by SlowPro48 View Post
    Are you sh'ing me? Motors (cranks) don't have a balance shaft. They have counterweights on the crankshaft.
    Should I check my muffler bearings too?
    Apr 2010
    I'm thinking it's more engine design, certain "frequencies" make it worse. Mine does it but runs smooth as heck
    Apr 2010
    Jerry is like the GOD of the Isuzu world (he hangs out on the Planet alot as well as 4x4wire and a few other forums I think), he's been an Isuzu Master Tech for, well i think forever lol.I'll let you know what he says, I sent him a PM.
    Feb 2010
    Thanked: 19
  1. A/C only gets cold at higher RPMs...
    Last Post: 08/26/2009, 09:34 AM
  2. $2500 Tata Nano Unvieled
    Last Post: 01/10/2008, 06:48 PM
  3. RPMs are over revving
    By Offroad vx in forum VX Troubleshooting...
    Last Post: 12/29/2007, 06:21 PM
  4. Trans shifting and RPMs?
    By 14erclimber in forum VX Troubleshooting...
    Last Post: 09/26/2003, 10:11 AM
