Results 1 to 15 of 18
Thread: lift questions
    Apr 2009
    2001 Proton
    lift questions
    Just finished a 3" lift on my VX and she looks awesome.
    A quick question.... The ball joint flip, Is it the top ball joints that are done and what advantage does this give?
    Next..... Do I stay with the standard wheels/tires or go for something with a nice deep off-set and stick some 32" rubber on them? mainly for show but I'm hoping to go play in the dirt at some point.
    IIRC, the ball joint flip just helps with alignment issues.
    Caution: You do need to get an alignment done after the lift. Make sure they don't adjust your torsion bar crank as part of the alignment (don't laugh - it's happened).
    Living in Florida, you don't need mud tires. You'll bury your VX in the sand with that tread. A decent all terrain tire (AT) will probably serve you better. With the 3" lift you should be able to run those 32's with no problem (maybe even 33's - that's what I run with a 3" lift, with significant trimming of the front cladding).
    99 Silver VX
    I think he meant camber, however the differece is minimal...
    Also, it mostly helps with adding a little bit of droop (or downward wheel travel) aprox 1/2"
    If you want more droop, you can add spacers under the A-arm and above the ball joint...I use 2" spacers and have great wheel travel...
    1/2" ones are available, somewhere....
    Apr 2010
    See my sig for pic of 33's on about 3" of lift, maybe a tad less, just OME 912 springs and a t-bar crank. As far as sand, it depends on where your at, when I lived in central florida I ran into plenty of mud but also sand and up here in north florida it's alot of red clay/sand/mud. I went with mud terrains but that's just me. I won't be playing in the sand a whole lot
    Apr 2009
    2001 Proton
    Thanks all. As I say, it's mainly for show. Any off road stuff here is sand/mud stuff.
    Think I'll flip the ball joints this weekend then get the wheels aligned next week.
    Which way does the torsion bar crank normaly throw the alignment out? toe in toe out?
    Apr 2010
    toe is not affected, toe is different than camber. You will have positive camber after a torsion bar lift (tops of the tires stick out further than bottom). Depending on how high you go, after your BJ flip you may not even notice it but should still get it aligned. Here's a good read on caster, camber and toe:
    http://www.ozebiz.com.au/racetech/theory/align.html
    Apr 2009
    2001 Proton
    So will the ball joint flip help replace negative camber?
    Apr 2010
    It'll push the control arm up more pulling the top end a bit yes. May not get rid of all of it but some
    definitely take it to a good alignment shop after you lift and let them know you are lifted so they dont adjust your torsion bars back down to stock
    the ball joint flip will help with camber, but you will more than likely need shims on the control arms that will look something like this
    iirc the big one is a camber shim, the smaller ones are caster shims, then the toe angle you adjust with the tie rods
    Apr 2009
    2001 Proton
    Flipping this weekend it is then.
    Thanks
    Apr 2009
    2001 Proton
    So I took my VX to my local wheel alignment shop to have the alignment done and yes, they wanted to crank down the torson bar/lift to adjust the wheel camber, as did the next two shops I went to. All three told me that is the ONLY way to re-align the wheels/camber angle.
    Where/how is the adjustment made without lowering the front?
    Apr 2010
    lol, stupid shops. See those shims that etlsport posted a picture of? The unbolt the upper control arm and use those shims to move it outward to change the camber.
    Apr 2009
    2001 Proton
    I've flipped the ball joints so am I correct in thinking this will help pull back some negative camber?
    Where do the shims fit on the upper control arm? any photos?
    Apr 2010
    Here is a photo of another Isuzu, same setup though. I added some lines and a caption lol
    Those bolts go through the mount (black area there) and come out the backside and go through the control arm crossshafts and get a nut on them. Between the crossshaft and the mount, you use shims to change camber
    Here's a pic of the control arm not installed, see teh crossshaft that would be running behind the mount
    Apr 2009
    2001 Proton
    So I would need to add shims to give negative camber?
  1. To lift or not to lift that is the question
    By CatFish in forum VX Talk...
    Last Post: 03/28/2012, 04:15 PM
  2. Stock 18" and Lift... questions..
    By SilverBullet75 in forum VX Talk...
    Last Post: 12/29/2008, 10:26 PM
  3. some lift questions...
    By So-CalVX in forum VX Modifications...
    Last Post: 05/22/2008, 07:47 AM
  4. Simple Lift Questions
    By Grand_Canyon_VXer in forum VX Modifications...
    Last Post: 10/29/2007, 01:52 PM
  5. Lift thread to end all lift threads
    By tbigity in forum VX Modifications...
    Last Post: 05/22/2007, 11:54 PM
