HI all, is the jdm tod computer located below our driver seat. if so then part number 8971319762 is its number.
checking myisuzuparts dot com it comes up as a abs control unit for a 1992 trooper...which sort of makes sense. is this just a naming convention and it is the control unit for our JDM TOD?
can someone confirm this for me?
i ask as my tod computer is kput. and i am trying to track down a replacement. the US tod computer listed for the US version of the vx will not be compatible due to the constant TOD mode.
I have had a Isuzu specialist spend 4 hours today trying to read the tod computer. he was able to talk to everything but the tod computer. Oh found out that my airbag module is shot and the pervious owner has removed the bulb from behind the dash to hide the fact
My rear left speed sensor is also gone. But on the good news he only charged me for 2 hours work and not 4.
Cheers
just found out that the 1992 jackaroo tod system has three settings: 2WD, which is best used around town on dry pavement; TOD, which automatically directs power to the front wheels in the event of rear-wheel slippage, and 4Low, a low gear range which offers maximum traction at low speeds. (taken from wiki)
