Page 2 of 2 FirstFirst 1 2
Results 16 to 22 of 22
Thread: License plate delete cracking! Can I fix it?
  1. #16
    Mar 2012
    sold
    Or ...
    ... how about covering that opening with an LED light bar
    yes, yes...or maybe an upskirt camera? im just spitballing ideas here..
  2. #17
    Nah, the camera would kill your approach angle
    & make you crosseyed.
  3. #18
    '01, Proton, VehiCROSS, 0229
    Thanked: 15
    If someone WERE to make one of these, keep in mind it has to be a little flexible. I didn't realize this until I had mine included in the LineX spraying. It doesn't have to flex much, but it does just a little to make it work
    Ty
  4. #19
    You might have some luck repairing that piece with Apoxie.
    You actually use it as a clay to reshape the broken pieces then it turns to an epoxy-plastic after curing.
    Then after a good cleaning, paint, & primer, use a matte UV Clearcoat.
    That's the best I got.
  5. #20
    2000 FIREFOX 0009
    I have one thats never been used and has been stored since I bought the vx new. What are they worth?
    Thanks Steve
  6. #21
    Mar 2012
    sold
    Quote Originally Posted by RAZ View Post
    Thanks Steve
    no idea... if i could get one in great shape for around $20 i would consider that reasonable, but for much more than that i will just put a license plate on the front or repair the old one
    its almost like its rotting - like heat has got to it and its lost its integrity and started to crack - when i took it off to check it out the rubber screw hole ripped out so i glued a washer on the back to be able to screw it back on the car, but i dont like knowing its jimmy rigged so id like a better solution
    if i did try to redo the one i have i would most likely have to fill in the cracks then cover the entire delete with something to keep moisture/heat from making this happen again... vinyl wrap? prob wouldnt match the cladding
  7. #22
    They usually sell for $40 - $60 used. I sold mine last month for $50, in excellent shape as I bought it new about 4 yrs ago.
    Check with Phil at St. Charles. PLACE AN ORDER for anything you want!
    Remember my experience with the interior door handles about 3 months ago? Phil said it would be 8-10 months, "maybe" but he didn't expect it to ever actually come....and I got them in 3 weeks.
    And now cobrajet's story too.
    You've got nothing to lose!
  1. New License Plate!
    By ohiovx in forum VX Talk...
    Last Post: 04/12/2014, 09:25 AM
  2. Need Help with License Plate LEDs
    By vt_maverick in forum VX Troubleshooting...
    Last Post: 03/01/2012, 09:10 AM
  3. License Plate delete
    By sloop in forum VX Talk...
    Last Post: 02/25/2011, 05:44 AM
  4. License Plate
    By SomeBeach in forum VX Talk...
    Last Post: 07/06/2009, 09:47 AM
  5. License Plate Bracket
    By johnny in forum VX Modifications...
    Last Post: 10/23/2002, 11:56 PM
