Results 1 to 15 of 20
Thread: Is this my power steering pump?
    Jun 2005
    01 Dragon Green VX 1286
    Quote Originally Posted by hellomoto View Post
    How do you check / fill the AC compressor? I've never checked mine
    sorry for the thread jack... you take it to a place that has a way to evacuate the system and fill it with freon.. if its not working that is probably what is wrong.. unless you have leaks or other issues.
    A/C is not really a do it yourself kinda thing with all the laws about freon collection (global warming). I have tried to fill it with the freon you buy off the shelf at local auto parts store.. didnt work because they are pressure sensitive.
    good luck
    jeff
    Dec 2002
    2001 Ebony 0177
    the AC lube is neon green...almost like old fashioned antifreeze. It may appear clear on a painted metal background, but it's glow-in-the-dark green. When the front main seal goes in an A/C compressor, it'll often drip/leak for a short time, before the A/C goes hot...good luck, The compressor is pricey
  1. Replies: 4
    Last Post: 06/06/2017, 08:53 AM
  2. Power Steering Pump Failing
    Last Post: 12/09/2015, 05:38 AM
  3. Screech on startup in the Power Steering Pump
    Last Post: 06/04/2015, 11:54 AM
  4. power steering pump bleeding??
    Last Post: 07/12/2013, 12:38 PM
  5. Power steering pump going out?
    By Grif in forum VX Troubleshooting...
    Last Post: 08/26/2010, 08:44 PM
