Results 1 to 15 of 18
Thread: VX engine swap
    Apr 2010
    1999 vx
    VX engine swap
    Im in the process of buying a vx with a blown motor..What would be your suggestion on a engine I should put in it?
    Apr 2010
    Well easy swap could be a 3.2/3.5 dohc engine from an isuzu, after that it's open to whatever you can either afford or have the skills to put in yourself. A fairly simple swap to me would be a chevy 4.3 V6. You could run EFI or Carb (up to you), if you go EFI you will need to get a computer/wiring to run it, also you would need an adapter froma Fiero store to adapt a GM 90* engine to the 60* trans, or you could run a chevy 2.8/3.1/3.4 and it will bolt up to the trans, just need to make motor mounts and what not for it. Your possibilities are endless!
    Apr 2010
    1999 vx
    Im leaning toward the 3.5 dohc from a 2002 trooper... My brother owns a custom shop so Im thinking of sending out to him with a a trunk of cash (lol) I was also thinking a diesel from a trooper ...If you had any choice of engines what would it be?
    Jan 2007
    VX Skeleton owner
    Thanked: 6
    I have a stock vehicross motor for sale here
    Apr 2010
    If I could pick a motor, one that is reasonable to fitting, I'd want either a Cummins 4BT diesel or a Magnacharged 6.0 LSx engine.
    caddy has a 4.0 V8 that supposedly bolts right up to the 4L30E trans... dont think its been done, especially not on a VX, but in theory it works if you get the computers right
    http://myweb.cableone.net/bcanderson...uroraSwap.html
    Feb 2010
    2001,Kaiser,1130
    don't use the trooper engine! Use the Axiom's first years engine. Why would you spend all this money and not get a more reliable version????
    disasterlady Guest
    Exclamation Need new engine ... or rebuild
    sooo, does anyone know what the best replacement engine is for my 99 VX 3.5 v6? came off the freeway this weekend with a knocking that grew louder by the moment... got it to my mechanics who hasn't opened it up yet, but thinks it's a rod, oil was black, knocking incredibly loud from engine. so sad, I want to replace with same engine but newer and without mods unless these engines are not good to begin with and a different engine would be better? Mechanic doesn't want to do a rebuild and his estimates would cost about $2k- $2.5k for rebuild. I heard GM is buying these engines now... anyone know what one would work for the VX?
    Please if anyone has done this and had good results, please let me know? I don't need opinions that aren't tried and true. =]
    You guys rock with the help.... thanks
    I intend to keep my VX for life.
    2001, IronMan White, #440
    Smile
    Listen to Atilla. There's a guy out in Austin that put an Axiom engine in his VX. Use the search button because there is a write up somewhere. Also, BigMeat just put a 5 speed in his VX recently. Again, use the search button to find the articles on it.
    Peace.
    Oct 2003
    1995 Isuzu Trooper LS
    Quote Originally Posted by atilla_the_fun View Post
    An 02 Trooper engine should be fine, that would have the redesigned oil rings.
    99 Silver VX
    The upgrade actually came sometime midyear 02...as my 02 Axiom STILL had the older style valve covers??? Also the updated 03-later engines have a much better PCV valve...My 02 Axiom engine (dealer installed in VX) is great! 230 HP and NO oil. Consumtion at 60K + miles....
    If it were me, Id buck up for the 250 horse 04 version...with direct injection....
    A little more computer swapin, but well worth it!!! In the future, expect to see folks experamenting with alternitive fuels on this engine, as with DI, the possibilities are enless....much improved gas mileage as well.
    And DI engines can handle much more boost, in the event someone wanted more power....
    Oct 2003
    Quote Originally Posted by BigMeatVX View Post
    I am told the ring upgrade can be detected by the presence of a screw-in PCV valve, versus a push-in one. Obviously, this should be confirmed on the subject 02 Trooper engine before jumping on it...
    Before deciding you will want to look at your states laws on engine swaps and emissions.
    I know some states out east are rediculous with their emissions/aftermarket laws.
    Here in Az the donor engine must be the same year or newer(which the above options are).
    99 Silver VX
    Yep, however, SOME 02 troops may have come with the newer screw-in setup, but they continued puting the older push-in PCV style engines isuzus untill at least midway thru 02....this is why my 02 Axiom had the older push-in style...but on the VX when I had the 3rd engine installed, they gave me an 230 Horse, 03 model with the newer screw in style PCV and the better rings...
    Like BigSwede says, best to confirm this first...dont just assume if its an 02 engine, that it is the updated one....
    Apr 2010
    Or just swap in one of these and be done with it
  1. Engine Swap
    By WiSDoM in forum VX Modifications...
    Last Post: 12/26/2015, 02:11 PM
  2. LS4 V8 Engine Swap
    By Leon R in forum VX Modifications...
    Last Post: 02/28/2015, 07:39 AM
  3. What would be your dream engine swap?
    By VehiCrow in forum VX Talk...
    Last Post: 08/22/2013, 07:39 AM
  4. Has anyone DONE the axiom engine swap?
    By ilya in forum VX Modifications...
    Last Post: 01/13/2009, 09:49 PM
  5. Engine swap
    Last Post: 01/30/2007, 06:49 PM
