Results 1 to 15 of 31
Thread: HELP tire question
    Thanks Sue, but I have 15" steel wheels.....I dont do well with change!
    2000, Ebony, VX, 0370
    Thanked: 12
    Lisa, are you looking to stick with BFG's? If so then you'll have to go with their line of tires, if not you may be able to find a tire with a similar look and size to the tires that you currently have. If you do go with an 11.5" wide tire instead of a 12.5" wide tire you will only be losing 1/2" per side so it will make a difference on how they look, but not that much. Run outside with a ruler and see if you could live with losing 1/2" from how far your tires stick out.
    What is the total size of your current tires (size and aspect ratio if it's listed on them....i.e. 285/60/R18)?
    current is 31x12.5x15
    I think I can live with give or take a 1/2 inch......LOL
    what brand/model tire do you have on there now?
    pro comp all terrain, used to have bfg's all terrain til they did away with the size......
    y'all I just am a tad freaked out by a 32" tall tire.....what do you guys think?
  1. Tire Question
    By SilverBullet75 in forum VX Talk...
    Last Post: 02/07/2007, 02:46 PM
  2. Tire question??
    By WiSDoM in forum VX Modifications...
    Last Post: 05/18/2006, 06:24 PM
  3. Tire & Rim Question....
    Last Post: 08/26/2005, 03:35 PM
  4. Tire Question
    By joesvx in forum VX Modifications...
    Last Post: 10/09/2004, 06:05 PM
  5. Tire wear question
    By drdavidr4u in forum VX Talk...
    Last Post: 03/17/2004, 05:10 PM
