Great info Billy, but not sure what you mean about the "window". Is it the lift, or sealing? "A" pillar wind noise? Or are you referring to the rear and the lack of view?
Are the dif's common to other Isuzu's as far as re gearing? I guess I'm showing my ignorance of all things Isuzu.
On that same note, what might be other common parts, e.g. drive line components, suspension components, etc. Although I have found that 912 springs from a Trooper (I was originally thinking Porsche 912, figured it out) work for a lift.
Thank you for taking the time to comment.
BTW where to you Tri at?
I used to also, here in south Orange County, CA.
Thanks!
R2M
