Page 3 of 3 FirstFirst 1 2 3
Results 31 to 45 of 45
Thread: manual transfer case swap
    99 Silver VX
    The AR-5 is also used in the H3 and Canyon/Colorado trucks and has a larger input shaft and different rear transfer-case bolt pattern as well...FYI
    Apr 2010
    Yup, just used the solstice as an example for the power output part I've done my research on that AR5 when I was going to use it in a Firebird build up in our shop. The truck versions also use a different gear ratio in 3rd than the Sky and Solstice versions. The truck versions also have a different shifter position and the "GM" AR5's use a 26 spline input, where as the Isuzu one is 24. The diameter is 1 1/8 instead of 1" but they use a smaller clutch disc than the Trooper AR5 setup. Also their bellhousing bolt pattern is different on an Ecotec engine, similar to like a 60 degree V6 but not quite, it's special. And BigSwede, what kinda clutch are you running in yours? I know my MUA5 held up nice on just 33's in the Rodeo and my random trips for over a year but nothing like what you put yours through
    Oct 2003
    1995 Isuzu Trooper LS
    My clutch is, um, whatever it came with when I bought it with 108K miles...
    I will say the Teralow (aka Revolution) gears probably save the clutch some grief off road...
    Apr 2010
    How do you like your Axiom Allan? My wife has been thinking about getting rid of her newer Camry for an SUV and I'm thinking of convincing her to get an Axiom lol
    Apr 2010
    Ya I know when I was going through the rock garden in Gorman that Tommy smelt a little clutch lol. Stock gears, stock clutch (or whatever was in it when I bought it) on 33x12.50's lol. I'm hoping to do some revo gears soon when I swap either tranny's or t-cases
    Oct 2003
    Attention to anyone contemplating a manual tranny swap - there is a guy on the planet parting out a manual tranny 99 Trooper.
    http://forum.planetisuzoo.com/viewto...=321049#321049
  1. Transfer case #'s
    By simonsayz1 in forum VX Talk...
    Last Post: 01/29/2015, 12:01 PM
  2. 2WD transfer case?
    By So-CalVX in forum VX Talk...
    Last Post: 03/03/2008, 08:40 PM
  3. Transfer case question
    By WiSDoM in forum VX Talk...
    Last Post: 01/23/2008, 09:09 PM
  4. TOD vs Transfer Case - Same thing?
    By jimbo in forum VX Talk...
    Last Post: 05/08/2005, 08:57 AM
  5. Transfer Case
    By yal^ in forum VX Troubleshooting...
    Last Post: 04/16/2005, 09:12 PM
