Hardeman, you can send that PDF file to Battlefield2142.Pilot@gmail.com
Thanks!
Thanks!
This is our bleeding procedure I posted here before. You have to remove the ABS fuse, and yes, the engine MUST BE RUNNING!
Mark
Mark must have posted the bleeding instructions just as I was hitting send on an email to you. The instructions that Mark posted are the same ones that I got from Merlin.
Thanks Mark, because now everyone can see them.![]()
also, check outmy how to guide on replacing the ABS module. the end of it shows a step by step on brake bleeding. just make sure you pull the abs fuse leave the engine running and do not let the master cylinder get empty
