Results 1 to 15 of 17
Thread: Brakes/Rear Door Panel.
    Feb 2010
    2001,Kaiser,1130
    If you're pads are new and squeaking its because the shiM behind the pad squeaks when pressed by the caliper against the rotor. It makes it sound as if need a brake job even though the brakes are brand new. To fix it you go to autozone or advance autoparts and pick up a tiny pack of "stop squeal" or brake squeal stop, they carry it at the registers. Take the wheels off, calipers off, pads off and apply this stop squeal gel/goo to the back of the pad. Then put everything back and your noise should be gone.
    I don't see how having the engine running affects the bleeding of the brakes? This makes no sense to me.. Just make sure to pump the brake pedal ~30 times before doing the brakes with the car off to pacify the ABS system
    Oct 2008
    2001, White, VehiCross, -
    I did that when replacing the brake pads. I applied this sort of lubricant substance.
    Do I have to reapply again?
    Thanks!
  1. driver side door panel
    By soggybottomboyz in forum VX Troubleshooting...
    Last Post: 11/03/2011, 05:41 PM
  2. door panel
    By harvey phillips in forum VX Troubleshooting...
    Last Post: 10/03/2008, 11:12 PM
  3. Removing door panel for window fix
    By Raque Thomas in forum VX Troubleshooting...
    Last Post: 10/14/2006, 04:25 AM
  4. remove outside door panel
    By jester0064 in forum VX Troubleshooting...
    Last Post: 04/22/2005, 06:05 PM
  5. How To Remove door Panel
    Last Post: 02/02/2005, 06:49 PM
