99 VehiCross 155K
I finally bought a transfer case off carpart.com with 8K on it. After shipping it came out to around 220$. I can see where they tried to remove the speed sensors and they broke the tab on the front speed sensor and really messed up the plastic with some pliers. How do you remove these sensors? Is this sensor with the broken tab ok?
My current system is giving me a rear speed sensor error code and I'm experiencing some severe "Tight corner braking". And I think I have a bad seal too because there is fluid sprayed all over the underside around the back axle.
Should I fool around with trying to replace the rear sensor, or just swap out the whole transfer case?
...lol the funny thing is ..it was the dash cluster after all ..not the speed sensor.
