Page 1 of 3 1 2 3 LastLast
Results 1 to 15 of 39
Thread: Aussie front locker install
    01, LineX tan/black, 1055
    Alright, day two of the locker saga. I have now spent about 14 hours working on this POS. Couple hours just getting cotter pins out. Lessons learned, to remove the CV joint, there is a retaining ring just inside the "green" cup that holds the balls and cup assembly. Just use a knife and pop it out. You have to remove the inner boot to do this. Had I known that, I never would have broken the axle seal, and saved a few hours of labor. To date, I have now replaced drivers side upper ball joint, lower ball joint, maybe a sway bar tie rod end, front axle seal.
    To make matters worse, my locker didn't fit. Requires .006 in min clearance between collar and pinion shaft. I ended up sanding down to 0.0065 one side and 0.004 on the other. That took quite a while.
    Over all gap after assemble" .142ish, min required .145. Better be close enough. If anything, it won't unlock, which is fine, cause I will be running 2wd high via manual hubs anyway.
    I didn't take pics, but it wouldn't be good anyway, a lot of cussing and screaming and running to parts stores. Now I am paying storage while the VX sits on the lift at the Hobby Shop. I should finish tuesday evening. Right now, CVs are in, diff mounted, full of Royal Purple. Good news, the cvs from Ebay fit just fine. Now I have my OEM set as spares. they were in good shape, boots were rough, but whole, and grease looked great.
    Sounds like a headache, just think of how your locked front end will be on the trails
    So it sounds like TOD will no longer work because the front end will always be locked. Is this how the locker is designed or is it because the locker doesn't fit the front diff correctly?
    His TOD will work when his hubs are locked, however BOTH front tires will be engaged.
    Feb 2009
    1999,silver, 1516
    TOD doesn't distribute power between the front wheels. It only distributes power between the rear axle and the front axle. The front is an open diff, so you might not get power to the ground depending on situation. If you get a front wheel in the air (not touching anything solid) all power would be sent to it and you won't really have pulling in the front end.
    With the locker in place, even if one wheel is in the air the other tire will get power. This greatly increases the off-road capabilities of any 4x4 vehicle. Now I want to see how long his front CV's hold up.
    Thanks guys, that makes sense. I've been in a 4x4 with a locked rear and felt how difficult it was turning, I assume that a locked front would be worse and almost impossible to drive on city streets.
    Feb 2003
    HAhahahaha LMFAO!!!!
    Isuzu CV's are so easy. Just messy, time consuming, and you gotta do it right.
    That story was funny, but woulda made americas most funniest mechanic videos with him cursing and throwing grease and tools for days!!!
    But, don't ever follow the book or manual 100% or you'll take apart way more than necessary and it will take you a whole lot longer to take apart, as well to put back together and will probably have a lot of you having it towed on its bare knuckles to the shop and paying them anyways to fix it.
    Aussie Lockers is what I was going to run in the ol' VX of mine as they disengage when turning. Then engage when wheels straight.
    So, they are not a real locker, but are supposedly stronger than a lockright and make a good lunchbox locker of sorts.
    Welding woulda just been cheeper and good with running Manual hubs.
    If you weld the rear axle spidergears be really careful with turns and get to know your new VX.
    Spazz-
    As for the rear end, no mods there, if you watch some of my utube videos, my LSD in the rear in tandem with ebrake works as well as a locker.
    VXorado, you are right, with an "autolocker" or "soft locker" in the front and manual hubs on 2wd, TOD will no longer be effective. Not because of the locker, but because the tires will roll independent of whatever the front axle is doing while the hubs are in 2wd. I never had any intention of driving with the lockers on the pavement. Too much risk for tearing up CVs and what not.
    Spazz is 100% right, just throw the stupid tech manual out for doing mechanical work. Now that I know how to disassemble front driveline, I could have saved hours of labor not breaking the various ball joints, and not ruined an axle seal as well. I am now confident that I could do this job again in one day, pending rust and cotter pins.
    As for the locker, the spacer collar was machined too big on both sides. My diff was spotless, no wear marks, and no looseness, oil was good. The error was on Aussies side, not mine. I know I read on the Planet or another site of someone having to shave their Aussie kit to get it to fit. They sanded the thrust washer, sounds like a bad idea to me. It is a sliding load bearing surface. Doing the outside of the collar, it was just a spacer and doesn't slide on anything. No harm, no foul if it relatively rough compared to the other surfaces. If you had a machine shop, it would be a real quick and simple fix, but doing it by hand on sand paper was no fun. As I mentioned, I am sure it will work as designed, but I probably voided my locker warranty. but since it only covers parts, not labor, not a big deal for something thats only 400 bucks, compared to the 800 or more it would cost in labor if I had paid a shop to do it. Waiting for new parts was not an option either, down my 2nd vehicle, sitting in a rented bay at the Hobby Shop cost me bucks. So I rolled the dice. I will let you know what happens.
    Feb 2003
    haha gotta Love that Auto Hobby Shop!!!
    Are they still $4 a day for a covered staul and $4 extra for a lift and you get 10 tool tags for tools?
    Thats the way Miramar was when I was there.
    If you needed more tools you gave up a tool tag for another set of 10 tool tags.
    $3 a day for an uncovered staul.
    I HAVE NOW JOINED THE LIMITED RANKS OF THE LOCKED VXs!!!!!!!!!!!!!!!!!!!!
    I did have another problem, had to call Mike at Indy4x, no help there. Couldn't get the hubs on and the C clip for the CV. He said it would be tight. Turns out, take a steel bar with a hole through, the proper pitch bolt, and a socket to use as a spacer, and then screw it into the CV. Sort of like a gear puller, only its a CV puller. Those bad boys are never coming off again....very tight fit indeed.
    For a covered stall with lift, its $5 an hour. If store over night, another 5 bucks. tools, no limit, just hand over your ID. I know most of the folks that work there, they are fellow Chiefs from my command, so I kind of do what I want.
    So here is the tally for the final product:
    Aussies-$365
    CVs-$120 or so
    Various ball joints-$150
    axle seal-$30
    Royal purple gear oil-$36
    Super Winch hubs-$120
    stall rental-$130
    So somewhere around 900ish and an IMMENSE feeling of accomplishment. I now know a helluva lot more about the drive train, and how to disassemble and reassemble stuff. I am just happy that it all works, and that my awesome friend from work took the time to explain how things work, such as the spider gear assembly, locker, various drivetrain terms and so on. I owe him big!!! I tested out the Aussie, no problems, I tooled around in the gravel with it in 4low, hubs engaged, disengaged, 4high and all the combinations. It is definitely a different beast in 4 low with it locked.
    If someone reads this that has manual hubs, does your TOD front power indicating light flash up and down at lower speeds? No worries, since I am in manual now anyway, TOD means nothing to me, I may have to black tape over the lights to keep it from annoying the piss out of me.
    97 Jap Import, Black BEAST
    Do the front Hubs need to be unlocked on the road even when in 2wd with an aussie locker. thinking of getting one? sounds like alot of work to fit it to the Vcross. Been reading installs on the trooper owners site and seems alot simpler.
    Oct 2004
    99 Astral VX 1032
    same install for the trooper and the VX.
    Yes manual hubs have to be unlocked when driving on pavement with a front locker.
    Ryan Christiansen
    Trooper Skid Plates, OME 912's, Stric9 Sliders, Load Warrior with extension, Apline sub in rear door, Apline front speakers, Alpine head unit, Definity Dakota MT 285/75 R16, Aussie Lockers Front and Rear, 4.77 gears and Warn Manual Hubs.http://picasaweb.google.com/RyanVehiX
    Quote Originally Posted by VX1032 View Post
    Well, not entirely true, I drove around quite a bit, but for daily driving, the front hubs should be on 4x2. Otherwise you get an annoying click and an occasional chirp. As for the install, it isn't that bad, mine was just so rusted, and I had never done anything like this, it was a PITA. I could do it again in 1/3 of the time.
    Go for it!!! Makes it a whole new truck!
    1999 Astral Silver VehiCROSS #1214
    Congrats Marlin! You've got more patience than I do. Mine was rusted pretty bad too so I gave up and had a mechanic friend of mine do the install. It was much less stressful! Not quite the same feeling of accomplishment though.
    ________
    BMW M60 HISTORY
    I can't find any suppliers?
    Suppliers for what? CV or locker? Locker is a no brainer, Matt at Indy 4x. As for CVs, Ebay has them, but I wouldn't run them locked. I will now have two new spares and a OEM spare, but those other two are for emergency use only.
    I am heading to the junkyard, there is a VX by my house, but I don't know how much he wants for the CVs. He only wants 1500 for the whole truck.
  1. Front and Rear Speaker install
    By LittleBeast in forum VX Modifications...
    Last Post: 06/01/2024, 05:48 PM
  2. ARB Front Locker
    By bartmanS4 in forum VX Modifications...
    Last Post: 12/11/2016, 07:48 AM
  3. Front ARB Locker install estimate
    By spaceCADETzoom in forum VX Talk...
    Last Post: 10/03/2012, 10:51 AM
  4. Replies: 28
    Last Post: 09/11/2011, 04:29 AM
  5. Front and Rear Aussie Lockers now available for the VX
    Last Post: 05/31/2007, 01:51 PM
