Results 1 to 3 of 3
Thread: at my wits end!
    Jan 2010
    1999,White,VX&1298
    Unhappy at my wits end!
    Hi Guy's and Gail's,
    I have a 99 VX (58k) that ran hot. After I had taken the time to replace the timing belt and Water pump. But no deed goes UN-punished it ran hot anyway, I found that the new water pump was leaking. So I got another one put it in but no soap it would not start. So I went through and re-checked my timing and found out I had a blow-ed head gasket. So I pulled both heads had a valve job done put it all back together, then found both out side boots bad (no biggie) but when I went to ad H2O I found I have a leak that seems to be coming from the rear of the engine. Is there a freeze plug that could have blown out? Could the block be cracked? Or is there a hose that I am not a where of that could be replaced to solve this very irritating/disheartening problem?
    All ideas/input appreciated
    tks
    James
    Wrench
    There are a couple of heater hoses that run under the intake manifold.
    The thermostat also lives down there in the hidden valley.
    Also, there is a "hard pipe" that comes off the back of the thermo housing that is sealed with an "O" ring.
    Fill the rad, start it up & let it warm up a bit,(put the rad cap back on so it'll build pressure) then look under the front of the intake manifold where the upper rad hose connects to the thermo housing.
    A sharp eye & a good flashlight may be able to see a leak in this area...
    '01 Ebony #0939
    Hi James,
    My only input would be to not give up, although perseverence doesn't seem to be a problem in your case anyway. It can absolutely be irritating when the problems seem to jump from place to place, but patience usually wins out in the end.
  1. Stalling. At wits end!
    By dallas121469 in forum VX Troubleshooting...
    Last Post: 05/07/2017, 05:49 PM
