alterasto,
here is the link. you actually may get one http://vehicross.info/forums/showthr...on+interceptor
about my problem: i drove home - no problem. also, i didnt go from 3rd to 2nd gear, after reading the topics provided by Ldub, i figured the mode switch could stop working for a while and then operate properly again. anyway, im about to clean, and change the fluid. will see if the pressure test will be needed
