So as some of you know I had my passenger side CV joint blow on me a while ago while mudding, well, I needed to remove the green CV cup to fix it, so I just took the passenger side CV joint off of the VX completely and was driving in 2WD until I had the time to drop the front diff and fix the problem correctly. Well I crawled under the VX today to lube some squeaks and what not, and to my surprize I was missing my driver's side CV shaft!!!!! The one that I had just left well enough alone. The outer cup had everything in it but there was no boot and the shaft was missing, and the inner cup had a torn up boot with the ring clamp severely bent 4 of the 6 ball bearings and the outer cage of the joint, the inner cage and shaft were no where to be found. The other day on the high way I heard a bit of a pop, but it really wasn't that loud and I assumed I ran over something, was that really the CV shaft breaking in half and pulling everything out? Is this what happens when you run 1 CV joint only? I just assumed that no power would go to that driver's side since we have an open Diff, did it break because of vibrations? I don't get it. I just checked everything 6 days ago when I did the oil change and other stuff..... What gives?
