I've been looking into a place to get some work done on the VX, these guys seam good,
http://neneoverland.co.uk/
Im looking for a majour service including brake fluid, transmition and diff fluids etc..... plus some other issues with the loose steering and air con clutch bearing.
They want £400 + VAT for the majour service, how does that sound. I have never had to get anything serviced before, lol. I just dont have the space or time to carry the service out. Its a fair way to go to get it done but it's worth doing things properly. Whilst its there for the service they will look into the other issues and give me a costs subject to part availabilities.
What do you recon??
edit*
list of issus might help, this is what i said to them
.Full service, Inc front and rear diff + gearbox oil changes, fuel filter etc.
.Something is loose in the steering, it’s wondering a lot and the steering wheel gets pulled around by bumps in the road etc. As well as a dodgy ball joint It may need the tracking / camber looked at. There are some shims on the upper front A arms that either need removing or adding too to correct the camber after lifting (the VX is lifted 3”) can’t remember which way around it is (I have a .pdf of the full workshop manual)
.Front CV joints are crunching a bit on lock when in 4WD (maybe I need to lower the suspension down a bit again as CV joints have quite a steep angle)
.AC Compressor bearings is completely dead and possibly the main front bearing on the engine (cant remember name) where the fan belt attaches too. I’ve put a new idler pulley, tensioner pulley and belt on it but these are more involved.
.It’s fuel economy has dropped a bit and there’s a smell of fuel in the exhaust fumes (especially when the condensation is steaming out in the cold mornings) Do you think the service would resolve this over fuelling? Or maybe a tune up?
.There’s a fairly heavy clunk in the drive train when the box drops down from 3rd to 2nd or 2nd to 1st. I keep the prop UJ’s greased up but would worry where its coming from.
.Lower ball joints on the front end need replacing (I replaced the upper ones in November)
its driver CV, possibly the front end camber, air con compressor bearings, loose steering.
