Results 1 to 4 of 4
Thread: Accumulator Piston Cover
    Anyone out there have/had this leak and fixed it?
    http://www.drivehq.com/file/df.aspx/...accupiston.gif
    I don't know if it is my pan or this accumulator piston cover.
    2001, Dragon Green, 1342
    Bart, since you don't know which it is, think I would just give it a really good cleaning, then sit back and watch and see.
    Well, it's time for me to do my tranny filter and fluid anyhow. I called Merlin about the accumulator leak and he said it is VERY common and the part to fix it are only $13 so I went ahead and ordered the part. So I will likely swap it at the same time I do my filter and fluid. The TSB calls for 2 special Isuzu tools but Merlin said it can be done with a little care and a flat blade screw driver. Cool thing is, I found one of the Isuzu J tools on eBay (the one for removing the old accumulator) so it shouldn't be too bad.
    Given how common Merlin said the leak is, I was just wondering if anyone else has had the issue.
    Well, nice to see a simple and cost effect fix.
  1. New Piston Rings for Oil Consumption Reduction
    By v2 in forum VX Modifications...
    Last Post: 08/25/2010, 04:23 PM
  2. where can i buy a vx car cover?
    By VeXy in forum VX Talk...
    Last Post: 06/01/2010, 07:49 PM
  3. Piston Ring Problem - Solution?
    Last Post: 07/04/2004, 12:58 AM
  4. Car cover for VX??
    By visconte in forum VX Talk...
    Last Post: 04/19/2004, 02:48 PM
  5. Car Cover
    By PBR in forum VX Talk...
    Last Post: 08/08/2003, 05:30 AM
