Results 1 to 15 of 23
Thread: rear end noise?
    Feb 2010
    99 silver vx 1144
    rear end noise?
    Have an odd noise from what sounds like the rear end? Just purchased last weekend so new to the vehicross. Sounds almost like an electric braking noise. Most noticable when letting off the gas and or decelerating kind of a vrr vrr vrr vrr then disappears when accelerating again. Any ideas?
    thanks,
    jp
    99 vehicross silver
    Jun 2007
    2001, Proton
    try Beano
    Thats what I do when my rear end starts making strange noises!!!
    Sorry I had to do that. Welcome to the board. I would suggest having a shop look at the rear axle seal. I had that issue and had to replace it twice. I blame the mechanic not the vehicle as it is a basic part found in most all vehcles. They also told me I needed a fluid change as it had never been done. As I had just recently done it I asked if they checked it or were just basing it on miles. They said they checked I asked to see it. We went out and sure enough clean as new. They were a tad embarressed
    Or the fluid may have been changed without putting in the LSD additive. Probably the best bet before taking it to a mechanic is to change the fluid to synthetic for a limited slip differential.
    Feb 2010
    99 silver vx 1144
    About how much did it run to have replaced and what do you recommend for fluid replacement on rear. I have to do the shocks as there spent want to do all fluids at the same time
    Feb 2010
    99 silver vx 1144
    and don't worry won't forget the lsd did that in my old truck, not so good!
    Mobile 1 seems to be highly recommended by the members here but it really comes down to personal preference.
    Feb 2010
    99 silver vx 1144
    weight?
    Oh crud. I can't remember. It should be in the owner's manual (available in the DownLoad section). I'll see if I can find it.
    Very easy to do yourself. Do a search and you will find how-to's on replacing pretty much every fluid in the VX. Plus you get the satisfaction of doing it yourself and knowing it was done right!
    GL-5 is the weight.
    Look here:
    http://www.vehicross.info/modules.ph...warticle&id=20
    It's on page 0B-7 of the shop manual (page 22 of the pdf file).
    When you go to drain the rear differential, you may need to 'plunge' the drain with a piece of wire or a zip tie (I had to on the front so assume you may run into the same issue on the rear). This is to move any debris out of the way so that the fluid can flow out.
    Feb 2010
    99 silver vx 1144
    Thanks, to you all. I've been looking for a vx forever and now having one I'm super stoked already took it up a mean hill this weekend. I better wait to finish repairs before tearing it up anymore. lol
    thanks again
    Welcome to the addiction.
    2000, Ebony, VX, 0370
    Thanked: 12
    I don't know if anyone else has run across this, but make sure that the noise is coming from the rear end and not your 4wd hi/lo stick shifter. Any time that I decelerate, or if I'm just cruising along at a constant speed I get a "gear" noise that comes through the shifter. I have an aftermarket knob on the stick shift so that may amplify some of the noise. While it's happening, if I push on the shifter a little the noise goes away. It's done that since I bought it, and I've had all the fluids replaced to the correct level with Amsoil so I know it's all clean and full.
    Thanked: 7
    Just basics, but make sure your tires are the same size with similar wear AND make sure they are inflated equally. Unequal tire pressure can make a whining noise when coasting.
    Anita
    2000 Ebony #263
    AnitaProtich.com
    Nov 2007
    1997 SILVER
    A bad axle bearing will make a whirr - whirr - whirr noise when coasting.
    If it is bad, replace both.
    They are not expensive, and both have gone around about the same number of times.
    PK
  1. Front and rear (rear) driveshaft joints are different?
    By 89Vette in forum VX Troubleshooting...
    Last Post: 10/05/2013, 09:02 PM
  2. Noise from below
    Last Post: 09/14/2012, 04:48 PM
  3. rear end noise when coming to a stop
    By evillecutter in forum VX Troubleshooting...
    Last Post: 06/19/2012, 06:52 AM
  4. New noise.
    By crager34 in forum VX Troubleshooting...
    Last Post: 08/02/2011, 11:53 PM
  5. Noise Help!
    By gregory46 in forum VX Troubleshooting...
    Last Post: 11/24/2003, 06:20 AM
