View Poll Results: What is your VX Oil Consumption in 1000 Miles?
Voters
199. You may not vote on this poll
  • 1999 - No Consumption
    24 12.06%
  • 1999 - 1/4 Quart
    11 5.53%
  • 1999 - 1/2 Quart
    13 6.53%
  • 1999 - 3/4 Quart
    6 3.02%
  • 1999 - 1 Quart
    15 7.54%
  • 1999 - 1.5 Quarts
    9 4.52%
  • 1999 - 2.0 Quarts
    12 6.03%
  • 2000 - No Consumption
    15 7.54%
  • 2000 - 1/4 Quart
    6 3.02%
  • 2000 - 1/2 Quart
    4 2.01%
  • 2000 - 3/4 Quart
    4 2.01%
  • 2000 - 1 Quart
    4 2.01%
  • 2000 - 1.5 Quarts
    2 1.01%
  • 2000 - 2.0 Quarts
    3 1.51%
  • 2001 - No Consumption
    32 16.08%
  • 2001 - 1/4 Quart
    12 6.03%
  • 2001 - 1/2 Quart
    12 6.03%
  • 2001 - 1 Quart
    10 5.03%
  • 2001 - 1.5 Quarts
    3 1.51%
  • 2001 - 2.0 Quarts
    2 1.01%
Page 7 of 7 FirstFirst ... 3 4 5 6 7
Results 91 to 96 of 96
Thread: What is your VX Oil Consumption in 1000 miles? Part Deux.
  1. #91
    Wrench
    The Ironman I recently aquired is a real thirsty girl...as in: almost a quart per hundred miles...
    When I get a chance, my plan is a couple quarts of Rotella + a pint of Seafoam in the crank case for 1-2C before the next oil change.
    Then go through the PCV system & treat her to a new PCV valve. (looks like the orig still in there...with 152K on the clock)
  2. #92
    DUDE!!!!
    Oil catch can alla way
  3. #93
    Mar 2015
    Well I just had the oil changed on my 1999. Ran 2000 miles total after purchase, and had the original (date of purchase) oil changed when I arrived in Phoenix, about 400 miles later. Changed it again after arriving in Utah. Dipstick still showed full, no signs of leaking, afaik. I'll be changing mine every 3k miles regardless. I swear by Rotella T6.
  4. #94
    I've switched to Rotella T6 for the last two changes as well as using BG EPR (109)...I've reduced my oil use by 50% down to about 1/2 quart every 1000 for the OEM spec of 1 quart per 1000.
  5. #95
    Me too, recently found Rotella T6 at Walmart for a reasonable price. I'm hoping the Rotella can help clean up my engine and reverse the oil burning woes.
  6. #96
    I think that what confuses me the most about this issue is that I'll go a few tanks of gas with almost no usage and then hit a period where it uses a half quart in 5-6 days. I'll top it off and then back to no usage for a while. Just seems to be so inconsistent that I don't understand what would cause it to be like that.
  1. Replies: 47
    Last Post: 07/22/2013, 02:07 PM
  2. Need new lift and have $1000 to spend
    Last Post: 09/01/2009, 04:30 PM
  3. 2008 Baja 1000
    By MoonRaker in forum VX Talk...
    Last Post: 03/30/2008, 06:57 PM
  4. Where's Waldo Part Deux
    Last Post: 06/10/2005, 03:17 PM
