Results 1 to 15 of 30
Thread: Dead Camera after cold snap
    Oct 2008
    UK Sunburst Ltd 000/175
    Hi u all,
    well after the coldest period in the UK for 30 years, the display when reversing is blank (except a few seconds displaying the word "CAMERA") rather than a view of the road behind. There is a audible click at the back of the VX when R (reverse is selected), possible a relay but not sure. I suppose I have few questions but generally I'm hoping for help.
    Is there a movable protective camera cover that covers the camera when not reversing that uncovers the camera when reverse is selected (has anyone had it fail?). It's still cold has anyone had experience of a camera coming back to life after a cold period? The camera is in the rear door how can I access the camera? I know you can see a set of two clips and a set of six hex bolts accessible after removing the spare wheel - what are they for? If there is a camera cover mechanism, what's it like, and can it be repaired? If the camera itself has failed in the cold has anyone replaced it?
    I know lots of question but as the camera is only on the JDM VX I don't believe it has been discussed much on the forum. A search came up with zero.
    Anyway hope you can help
    Regards Kirk
    Kirk,
    I'm guessing since I don't have the JDM but ...
    I doubt there is a protective cover over the camera. I'm guessing that there is probably not even a relay to power the camera. The camera probably receives power directly from the reverse lights.
    The first step you should take is to check all of your fuses. Also check to make sure that your reverse lights are working. It's entirely possible that the reverse switch (turns on reverse lights) in the tranny is not functioning properly.
    Even though you may not have a CEL, have the codes read. An error code could be stored that does not trigger the CEL (it happened on my TLC).
    BTW, the electrical manual is in the download section. I think the reverse light section starts on page 112.
    Oct 2008
    Hi Tom,
    thanks for the suggestion. I forgot to mention that during the cold period of course I've been driving the VX, and after a short trip to the dog kennel I parked up on my driveway. During the park up, the camera image did return briefly (until I turned off the ignition). The next morning the camera image was again blank and it has been the same for the past week or so.
    I've also taken out the spare wheel to see what was behind it. There is a cable coming out of the enclosure that the camera is housed which has an inline connector 8 inches from the enclosure after a grommet.
    As to the possible camera cover. If it doesn't move the plastic cover that covers the camera aperture can't be fully opaque (but it certain seems to be)
    But that suggestion of the reverse light fuse is a good place to start further investigation. I appreciate you stateside guys might not appreciate the camera but here in the UK (and elsewhere I imagine) everything (roads, junctions, parking) is so much tighter (please not dirty jokes)
    Kirk
    Jan 2007
    1997 Silver JDM
    Hi Kirk,
    There is a cover that opens to allow the camera a view of the road. the most likely diagnosis is that the cover has stuck shut (I have the problem that mine sometimes remains open as the headunit doesn't necessarily send the "shut" signal) or isn't receiving the "open" signal, but as the H/U says "camera" then that's unlikely really.
    somehow you need to trigger the camera and give it a bit of a push I'd say...
    Hope that helps,
    Alan
    I stand corrected about the cover. It doesn't seem to be the best engineering approach but then ... I noticed they didn't ask my opinion.
    I know how useful the camera can be. Our RV has one & the display went Tango Uniform recently. Lane changes must be done with extreme caution till fixed.
    You might want to disconnect your battery for 30 min. Sometimes that corrects software glitches if that's the problem.
    Jun 2007
    2001, Proton
    might be frozen shut
    It happens with locks, door handles, etc I suggest a blow dryer for a fe wminutes as well as shifting from rev to nue a few times
    Yeap there is a cover as said above. Id do what circmad said and then give it a shot.
    If you really want, you can actualy put a switch on the signal wires to the camera so when your driving along you can have it running too.
    I can upload a diagram of how this is done.
    But to actualy get to the wires is a real pain there beside the jack but theres a little metal cover thats in the way that you have to remove so that consists of undoing some of the plastic interior etc.
    Oct 2008
    No Happy Return of the Season
    Well, the warmer weather has returned but my camera hasn't. I've tried to push the camera cover, as suggested, but no joy. No really sure how it moves/pivots (back, left, right, up down) and there doesn't seem to be movement in any direction; I don't really with to force it. It seems to be jammed. Does the camera cover work on a solenoid or a motor driven gearing (would I hear the difference)? The best answer is poss to remove the blackish plastic rear door arch (?) insert that covers the camera and camera cover. Has anyone removed the door insert? How is it possible?
    Any suggestions?
    Kirk
    Wrench
    Quote Originally Posted by kirk hilton View Post
    Any suggestions?
    Kirk
    IIRC, if you remove the spare, you can see the hardware that fastens the plastic half moon cover from inside the door.
    Oct 2008
    Yes I've seen the two clips behind the spare wheel. If the two metal clips are removed the half moon insert still seems held firm. Is it a case of a firm tap with a hammer on the two plastic pillars that protrude thru the metal of the door? I don't want 2 force (and break a pillar) if there is more to it.
    Kirk
    Kirk
    My "guess" would be double stick tape, but since I haven't had mine off...
    Anyone wanna kick in a more experienced opinion?
    Edit...searched "half moon" & found this..http://www.vehicross.info/forums/sho...ight=half+moon
    Jan 2010
    Green 3.2 needing TLC
    Hi Guys, I am also needing to know how to remove the half moon cover from my newly purchased VX, I have removed all 6 nuts and taken off the to clips but nothing is shifting. I even tried tapping on the center of the plastic lugs with a punch and I can now recommend the no one else does as the plastic is very thin and with 2 taps it has made a bluge visible from the outside. I can only guess that as well as the clips it must be also stuck on!
    The old display head unit was broken when I got it and after following some sound advise from Alterastro I replaced it with a fantastic new headunit that suports the rear camera, Unfortunatly the Camera also seems at fault, because when in reverse it changes to the camera automatically but after 2 seconds shows "NO SIGNAL".
    The camera unit has power going to it so guess its the camera itself?? either way I need the back cover off and the camera out, firstly to test it and secondly (if it is broken) to find out what replacement will fit in the space.
    Oct 2008
    Quote Originally Posted by FuddyMucker View Post
    Hi FM,
    that's exactly my experience with the half moon cover and also my concerns with the plastic lugs.
    It's interesting that after a couple of seconds you get 'no signal' as I just get the normal 'Camera' message suggesting that it's just the cover that not moving out of the way which is a fault.
    The half moon insert is the same on the US VX so hopefully the guys can give advice. It might be that this issue is raised on another thread (ie not this JDM thread)
    Kirk
    IIRC it is held on with double sided tape like the rest of the cladding pieces.
    Maybe use some dental floss and and try to cut through the tape.
    And to your answer i think it is motorised, as when i turn mine on and off i can hear the flap shut.
    it goes up and down.
    Ill try find a pic of the half moon without the cladding on it. if i get time.
    Jan 2010
    Done it!
    Yes it is also held on with double sided tape (quite well)
    1st off you need to undo the 2 middle nuts (out off the 6) and slide off the 2 tin clips from the plastic lugs. Then I took one of the babys solid plastic dinner knives and sharpened it with an angle grinder (while the missus wasn't looking). Then I pushed it between the plastic half moon cover and the metal boot and followed it around the outside. Worked a treat, now I can remove the other 4 nuts and take off the camera.
    Hope this helps (and you have a plastic knife to hand )
  1. Loud snap or clank in 4wd low under heavy load.
    By Nikad92397 in forum VX Troubleshooting...
    Last Post: 01/15/2017, 01:59 PM
  2. rear seat snap strap.
    By JAMAS in forum VX Talk...
    Last Post: 09/06/2010, 08:13 PM
  3. Snap Ring Size Help!!!!
    By Bimati in forum VX Talk...
    Last Post: 06/02/2007, 08:19 PM
  4. Front Axle Snap Ring...
    By Twilight Imaging.net in forum VX Troubleshooting...
    Last Post: 04/09/2007, 08:40 PM
  5. Bearings-Snap ring won't fit
    By Bimati in forum VX Troubleshooting...
    Last Post: 02/20/2007, 04:46 PM
