David, I'm very glad you found the leak! That is half the battle! And glad my write up worked well for you.
You can probably get the rubber washers and new bolts from Merlin for pretty cheap. I would just call him and order some so you have them.
So, what you are saying is that the oil leak was coming from BEHIND one of the camshaft pulleys?
That's pretty crazy. I wonder if you should buy new camshaft pulleys and seals also. I've never heard of a leak from this area.
