I am looking to replace my worn serpentine belt and was just wondering if there are any tricks or concerns that I might need to be aware of? Any information would be greatly appreciated.
Thanks,
Neil
Thanks,
Neil
Take a look at this thread...
http://www.vehicross.info/forums/sho...erpentine+belt
 Super VXer
						Super VXer
						Too bad it is old posts or I would have replied there. I did this myself last night. I bought the belt at Autozone and used their excellent lend a tool program for the tool mentioned. This is an excellent time too differentiate between a job that is easy based on knowhow required and easy based on level of difficulty. The serpentine belt replacement requires like zero know how but it does require patience. The job is not a fix on the side of the road with bare hands as suggested or your tensioner is shot. However due to the placement of the pulleys you can get the tensioner to move just barely enough to get the belt on. If doing by your self it can be frustrating not too mention big forearms can limit your movement. Doing it on a warm motor adds extra fun. But anyone can do it as even the strength needed is minimat with the tool
 Super VXer
						Super VXer
						I find a 14mm socket on a15" breaker bar works well to move the tensioner. Just a suggestion.
 Super VXer
						Super VXer
						 Super VXer
						Super VXer
						j,
they are talking about the serpentine belt. you replace the water pump with the timing belt which is inside the engine. the serpentine belt is between the radiator and the engine block, i have removal and replacement down to about 15 min now.
i think my last belt was around 30-40
 Super VXer
						Super VXer
						The belt was like $30 definately print out the attached link in the 1st post it has great diagrams. It was about 15 minutes and that was my 1st time. The only additional info is to get the spring to loosen you attached the 14mm socket to the pulley then pull it as if you were trying to tighten it. The other way just loosens the bolt on the pulley. And no water pump that as stated is with the timing belt.
 Member
						Member
						I don't mean to change the subject but this is the closest thread I could find. Here's the story...
My serpentine belt started to shear off so I had it replaced the next day with no problems. The only changes since then have been that Today I had a shop replace my muffler w/the superturbo from dynomax and add a stainless exhaust tip. When I got back to work I disconnected the battery to reset the computer. When I went to reconnect the battery a buddy of mine noticed that two ridges of the serpentine belt were over the edge of the 'water pump wheel' closest to the engine block. We moved it back into place and started the engine; only to have it jump back on the bay edge of the water pump. We have replicated this process two or three times and taken it for a test drive. During te test drive two ridges sheared off the belt. It's at my mechanics shop and will be examined tomorrow morning...where I will watch them examine the vx. I hope things are ok and the belt was faulty or something of that nature.. Also, my mechanic pulled the diagram for the belt and it was routed correctly.. Any ideas guys?!
		Sounds like a mis-aligned/bent pulley...
 Member
						Member
						Ldub to the rescue!! So, I attempted some online research and failed...epically. How do you remedy this problem if it is indeed the culprit? I'm also wondering what would cause this problem..thanx Ldub!
Thank goodness I have the State Farm Smart Car to drive around for the time being...
 Super VXer
						Super VXer
						Thanks Mark, looks very nice and the quieter/cooler feature sounds good! A couple of year back, the Gatorback belt was quite popular, is that not the case anymore?
Also, Ldub, the diagram you posted in the initial thread is not showing:
 Member
						Member
						So I got the VX back today..i'll try and post a picture of the old fan bracket. The serp belt looks good, and all pulleys are aligned. However, (when I test drove the vx on sunday approx 2mi to see how it was driving after they put the old bracket back on. I noticed strong vibration around 3500 rpms). Now that the bracket has been replaced, vibration is virtually zero while driving. When I am stopped and in gear there is annoying vibration. When I am in park or in in neutral, the vibration is very low frequency and not as noticeable. I searched the forums..and have come up with the maybe the motor mounts need to be replaced? I have also looked at the engine while running, and it seems to be moving a little more than usual...i'm a bit worried and i'm going to keep driving the smartcar until i can get this durn thing resolved 100 percent. Help is very much appreciated..
 Super VXer
						Super VXer
						Completely got confused here, I was not paying attention....I meant the serp. Dont want to mess with anything inside.
