Demon,
Check the ground on your trailer wiring adapter. Sounds similar to a problem I had in the past.
Am I going to need to remove the bumper to get to the ground? I can see the connection, but cant find any wiring underneath the car.
Also, the inside lights all work as do the exterior lights. I will go through the fuses tomorrow, once I locate the dash fuse box, and proceed from there. At least the heater is working, it is freakin cold here!
