I wanna know when they finally got around to perfecting "perpetual motion"...
I come from a long line of tinkerers/inventors who've been chasing that elusive goal for decades...
Perhaps you were referring to inertia?
I'd also like to see where you got this "fact"...please post a link if possible.
Also, You'll find that if you refrain from posting as a self proclaimed "absolute authority on all topics", & learn to leave yourself a bit of wiggle room, by throwing in a "possibly", "theoretically", "sometimes" or even "it's possible", you'll find you get called out a lot less often...
Jack, I've never seen a reason to apologize for calling "made up BS" for what it is...ESPECIALLY when it's been presented as fact.
Riff
FYI I am not Calling you out on this, Being a Tire Design Eng I like to look at things in many ways that affect a vehicle.Really the biggest thing right now is Rolling Resistance it is a MAJOR issue with all Vehicle Manufacturers and (TSW) Tire Spec weight is one of the causes of High RR I have not looked at Unsprung weight as possibly being a issue for stopping, more for ride and handling so I was just trying to get a idea what this guy was telling PrettyKittySprinkles was fact or just a guy wanting to make a few bucks upgrading brakes(But according to Ldub thats not possible because there are no big brake kits for the VX so it is kinda moot)
L-bud--- Dude, you seriously need to clean out the bowl in your bong-pipe, 'cause you've been smokin' too much carbon!!! God bless your little heart.![]()
This is the type of "fact" I'm referring to:
Where do you get those stats?...Got a link?
All the other info regarding unsprung weight & rolling inertia is true AFAIK.
Having some experience with MX racing bikes, I agree with riff, unsprung weight is bad with regard to how quickly suspension can react to sudden changes in terrain etc.
It's also harder on the equipment controlling suspension components, shocks in particular.
And yes, I agree that larger tires & wheels will generally create more inertia, hence longer stopping distance.
That having been said, IIRC the VX has one of the shortest, if not THE shortest stopping distance of any SUV ever tested in the years that were being reported in various magazines of the time.
IMO, once you've installed heavier wheels & tires, you quickly re-learn the diminished braking & acceleration capabilities of your vehicle, & drive accordingly.
And all that is just my opinion, worth exactly whatcha paid for it, maybe even less...![]()
ummm we may have already scared PrettyKittySprinkles away
Ashley,
You DO NOT NEED to upgrade your brakes for larger tires. Question answered.
Also, your CV boots will not just wear out due to angles caused by a lift (if you even need a lift to fit the tires).
I have been lifted, and running 33" BFG MTs for over 6 years now. I'm still on my original CV boots, and my original rotors. They are all still fine, actually, my rotors look brand new pushing 80,000 miles.
Brian
'01 Proton 1416
BBVX,
Where have you been? Awsome looking VX.
Peace.
p.s.
I like your tube bumper. I looks like a design Granda Pa Bob used on his VX. Yours looks like you took it up several notches.![]()
3 years of Rallycrossing and 3 years of 4" lift w/ 33' MTR's (6 years of real wheeling and Moab) and my CV's AND brakes were still the factory originals. The brakes were adequate for the bigger tires but stopping distances went up a bunch. This wasn't due to the brakes not stopping the wheels (I could lock them up no problem), but rather just getting that extra mass whoa'd down like everyone else is saying. I think driving style has a lot to do with the longevity of both and a little luck on the boots thrown in for good measure.
You're correct in that the increase in momentum of the rotating mass due to a heavier tire may well be the larger force acting on the brakes with larger tires, but it's not the only one. If the "unsprung weight" between two sets of running gear is equal, but the diameter of one set is larger than the other, the larger diameter set will cause the brakes to work harder, due to the longer moment arm. "Just sayin".......
Randy
I am wondering where you got your info from? I have seen many pics of vx's with stock tires totaled. And as far as that goes isn't it following too close that causes this to happen? I have larger and alot heavier tires than stock and have not rearended anyone . I think that the rubber lines on the vx brakes suck and that would be all I would change if there was a concern. And the stock pad thing,they are ceramic pads. If you go with a good ceramic pad then you do not need to by stock pads. shawn
1COOLVX
