Results 1 to 15 of 59
Thread: Help! I want bigger tires for my VX
    Also by larger brakes you are actually adding more unsprung weight unless your brakes are mounted inboard,really the unsprung weight should only deteriate the ride so you would lose alittle of the sport car feel and have more of a What I call soft feel. I have had many types of tires mounted on my VX and the biggest issue I have found is (ride) and it depends on the type A/T M/T or Performance ( cornering) never braking it always feels the same and I have never had brake issues.
    Wrench
    I think this all to be a moot point in any event, since there are exactly zero aftermarket "big brake kits" to be had...
    I believe you'll find the same number of multi piston calipers available.
    The hot tickee seems to be:
    Drilled, or drilled/slotted rotors
    Stainless braid brake lines
    OEM pads
    That's my theory & I'm stickin' to it...
    Nov 2007
    '01 Ebony Black VX, 0801; '01 Kaiser Silver VX, 1002
    I believe that the need for larger brakes is based on the larger diameter of the tires more than the weight. You're dealing with more torque (at the same road speed) applied by the road under braking (as long as you have traction) with larger diameter tires. Having said that, the handling decrease you get with really large tires will usually moderate your speed. I believe the stock brakes in good condition will take care of anything you need them to, unless you're racing........
    Randy
  1. is bigger better?? Tires that is
    By woody in forum VX Modifications...
    Last Post: 01/30/2008, 08:49 PM
  2. Got bigger tires, want to cranking the front torsion up a bit...
    By Grant Eaton in forum VX Modifications...
    Last Post: 08/07/2007, 04:05 AM
  3. 16 rims need new bigger tires :(
    By tooldini in forum VX Modifications...
    Last Post: 10/24/2005, 06:57 PM
  4. Always 1 Bigger
    Last Post: 11/25/2004, 10:24 AM
  5. Bigger wheels and tires
    By SusanR in forum VX Talk...
    Last Post: 12/18/2003, 12:10 PM
