Just thought I would drop this here:
http://www.danielsternlighting.com/p.../products.html
I use the 130/100 watt bulbs in my zuk, and man is it BRIGHT!
Convert to HID and you'll never go back.
-- John
isn't it a LOT more $$$ to do a good HID install? You need new reflectors, bulbs, and ballasts, correct?
Just plug-N-play...no new reflectors, but yes, bulbs, ballasts & igniters.
And yes, $200.00 is more expensive, but worth it...
This is considered one of the best values/service on the market.
http://www.xenonrider.com/products/h...hid_kits.shtml
The H-4 hi-low kit that Little Beast originally brought to our attention.![]()
I don't remember them being so cheap and easy
Now I want one!
?reliability?
Chi Dog...Dog is my Co-pilot
Onward thru the fog
I bought the Xenon Riders hi/lo kit too and installation was SUPER easy. I think it took me longer to run the wires cleanly than it did to install the kit. I've had them since a little before Moab and haven't had a problem with them yet. They fire right up and turn night into day.
I, too, would have to say that if you have the dough go with the HID kit, but if not, the bulb's that polie talks about are pretty bright in their own right and are a super cheap and easy "mod".
I picked up 'Silver Star' bulbs for Wifey's Eclipse. I'll eventually upgrade her to HD but ... one step at a time.
I haven't installed them yet so I can't tell you how much they help her night driving (SSHH, Christmas present).
my suggestion is check out ddmtuning.com
for around $200 you can get a full set of HID's with everything you need.
55watt ballast, any color bulb you want, hi/lo, and lifetime warranty.
i have ordered 2 kits from them and had no problems (i did have one headlight out for a little bit but it was due to wire corrosion from the battery)
