Page 3 of 3 FirstFirst 1 2 3
Results 31 to 43 of 43
Thread: Another ABS light
    Aug 2008
    Here's an even cheaper (< 0.01 cent) and quicker option without any labor involved to having the ABS light disappear. Simply put a tiny piece of Black Electrical Tape over the ABS indicator light on the instrument panel. Problem solved.
    That's how I got rid of the flashing clock on my first VCR...
    VX is due for inspection & was sure it wouldn't pass with the ABS lite on.
    Tried bending pin over & removing fuse. Lite still on. Pulled the dash cluster out & removed the ABS bulb. Only takes about 30 minutes & the only tool you need is a phillips screw driver.
    If I get a chance this weekend, I'll try a re-do whilst taking pix.
    BTW, there is only 1 fuse for ABS. The 20A one indicated on the cover is the one. The 40A shown on the cover is a fusable link, leave that in place.
    BBTW, inspector dude doesn't like black 'lectric tape over idiot lights - couldn't go that route.
    AFAIK, the ABS light does not trigger a CEL in the ECU, so you should pass emissions/etc. I have passed here in Reno 3 times with my ABS light on. Recently, I ripped out all of my ABS junk from the hubs and pulled the fuse. I just need to get that light out as well.
    Aug 2008
    Tom--- It's a good thing the Inspector Dude doesn't know about the pre-ignition ACC switch test light function for the ABS Light Bulb.
    Nov 2007
    1997 SILVER
    Tom,
    not sure that the OFH is a good mix with cheap Chinese wheel bearings.
    Have a good look at them before you put them in Mate.
    PK
    I'm with you on that PK.
    Inner bearings came with outer races but outer bearings came without. Also they shorted me an outer bearing. Don't think I'll be ordering from them again. I'll prolly just do the passenger side right now (to get it re-inspected) & then order a full set of quality bearings to do the full job next month.
    BTW, I've noticed that the brakes seem less mushy since the ABS has been disabled. Anyone else experience that?
    My brakes feel the same will all the ABS crap pulled out.
  1. Help with wiring light acces. to dome light
    Last Post: 11/24/2013, 08:49 PM
  2. Battery Light, ABS Light, No Power
    By TimG in forum VX Troubleshooting...
    Last Post: 03/22/2012, 08:23 PM
  3. Rear cargo light + underhood light
    Last Post: 05/29/2010, 08:00 AM
  4. spoiler tail light / hazard light question !
    By Spike in forum VX Talk...
    Last Post: 05/21/2007, 08:27 PM
  5. Dead short in Rear Light/Instrument light
    By Damien Jones in forum VX Troubleshooting...
    Last Post: 07/16/2006, 07:49 PM
