Results 1 to 3 of 3
Thread: Brake questions
    Jan 2008
    2001,Yellow, VX, 0795
    Brake questions
    Hello Fellow "Little Dragon" owners. Has anyone removed the front brake rotor to have it machined? I would be very thankful for details on how to remove the darn thing. I have the center hub removed and now I'm looking at a center piece with 3 philip screws. I tried removing the screws, but they are in pretty snug...not sure if they need to be removed
    Thanks for the help in advance
    Those screws are how you get to your wheel bearings.....you have to be very careful not to bugger them up when removing them....
    Are you the guy I talked to at the post office way back???
    Wrench
    Quote Originally Posted by TexasProton View Post
    These ought to clear things up for you... (from the "how to" section)
    http://www.vehicross.info/modules.ph...warticle&id=59
    http://vehicross.info/modules.php?na...warticle&id=58
  1. I brake for ABS
    Last Post: 03/19/2013, 11:06 AM
  2. EBC brake pads and Apex brake lines
    Last Post: 12/14/2011, 01:15 PM
  3. Brake
    By Mark B in forum VX Talk...
    Last Post: 06/02/2008, 05:08 AM
  4. using the e-brake
    By etlsport in forum Polls
    Last Post: 11/13/2007, 08:10 AM
  5. Questions about the brake/gas pedals
    By Ruflyf in forum VX Modifications...
    Last Post: 06/09/2006, 05:25 PM
