Results 1 to 15 of 16
Thread: starting problems
    Sep 2009
    '99,White,Ironman,1564
    Red face starting problems
    When I first turned on my VX in the morning it starts ok, but later after maybe 45 mins, when it starts then the RPM gets really low like it has no gas and sometimes turned off. I try changing the TSP, but I still have the problem. The sparks are the NGK platinum/iridium maybe one year of use. Any tip is welcome. Thanks
    Wrench
    Starting easily from cold, then starting with more difficulty when the engine has warmed up, is sometimes a symptom of fuel pressure regulator failure.
    Search "fuel pressure regulator" for much more on the subject...
    Welcome to the forums...
    Wrench
    This thread is especially helpful...
    http://www.vehicross.info/forums/sho...sure+regulator
    Mine was doing this a couple of weeks ago, i also cleaned the Iac valve ( idle air control) and it seems to idle better now and i have only had the slow start like cranking over and the gas slowly getting it.
    But yea id say Ldub is on the money
    Mine was doing the same thing recently. It sparatically die during start up, warm or cold. Even when it would start, it would sometimes nearly die out, it would drop to like 500rpms and it would struggle but come back to life, no gas needed. If I stepped on the gas, it would start better, but I would have to catch it before it stalled/died. I took it to get checked out at the dealer and they diagnosed it as a leaking intake manifold gasket. The expansion and contractions of the gasket made the problem intermitant (sp?). Hope this helps.
    My VehiCROSS
    Sep 2009
    Talking I fix it!!! That was it !!! The fuel pressure regulator
    Man that was it!!!
    The RPMs are now steady, no more starting problems in hot cranking. The pedal feels with more power. There was so much dirt inside. Imagine 125k miles on it. Wow, thanks a lot for your help. I use a single tool to the get to the back allen bolt, I'll post it in my profile. I don't know how to post it in the link so it can help others.
    Jan 2008
    1999 Astral Silver 0481
    Quote Originally Posted by Axelivan View Post
    Man that was it!!!
    Great axel,i'll add to all this to change your fuel filter which can be a bit clogged if you haven't do so
    Now go,have fun & enjoy that baby !
    Dakar was just the begining.
    Sweet! great news i also will be replacing mine as had another slow start the otherday, and hopefuly itl give me a boost in mpg.
    Prob get my mechanic to order it for me and ill install it my self with the guides on here it seems pretty straight forward!
    #%# No way im replacing it at the moment, over here our supplier for Isuzu parts is Holden they quoted $326 for the regulator saying it has to be imported lol. so yea no way
    1997 Silver JDM 0623
    Don't forget the coolant temp sensor - or the crank sensor both can efffect warm/hot running
    cheers
    Steve
    Isuzu Vehicross 3.2 V6 24 Valve
    Sep 2009
    2000, Foxfire Red Mica
    I had something similar happen once--the morning was cool, but not cold, and it started and ran just jim dandy. I drove it for about a mile, stopped it, turned it off, and let it sit for 5 minutes. When I restarted it, it died every single time I put it into gear. Restarted and re-attempted to drive it a couple times, finally got her moving, and when I got it up to speed the tranny was making horrific clunking noises when it shifted. Then it was fine, and has been since--no check engine light or anything. I took it in for a once over, but the mechanic had never worked on anything Isuzu and was a little bewildered at best anyways, so I never got a straight answer.
    Sep 2009
    thanks guys for all the comments. Those are very, very helpful. Specially the "do-it-yourself" FPR replacement. Simply great!! Thanks for been there.
  1. stalling when starting
    By circmand in forum VX Troubleshooting...
    Last Post: 01/30/2014, 04:48 PM
  2. Starting to take orders!
    By BOARZHEAD in forum VX Modifications...
    Last Post: 07/03/2011, 08:30 AM
  3. Starting problems lead to fire danger.
    By PK in forum VX Troubleshooting...
    Last Post: 10/01/2009, 11:19 PM
  4. multiple problems starting & driving
    By chrispin in forum VX Troubleshooting...
    Last Post: 08/06/2007, 05:04 PM
  5. Starting problems
    By PorkChopXpress in forum VX Talk...
    Last Post: 04/18/2005, 12:30 PM
