Results 1 to 12 of 12
Thread: Oil Change
    Aug 2005
    1999, silver, 0887
    Okay, I'll say this again inspite of what others have said against this method (Tone, included. God rest his soul.) I have found the problem with the VX engine oil usage has alot to do with the filler cover "O" ring and PCV valve. Specifically, change that "O" ring every oil change and screw the cover down tight using a pliers, and second only use the Purolator PV 1061 valve, it's superior in every way. With these adjustments oil consumption declines, as less oil is blown into the engine intake system. I know this sounds too good to be true, but try it, it works. We've applied this metod with our two '99's with good success.
    Sep 2008
    2000,Kaiser silver,VX,0576
    Quote Originally Posted by blacksambo View Post
    Hey blacksambo, at the risk of sounding stupid, where do you get the "O"ring ? I mean is it something you can pick up at like autozone or do ya need to order from merlin ?
  1. Oil change
    By Mihai in forum VX Troubleshooting...
    Last Post: 07/01/2009, 03:10 AM
  2. Oil Change
    By Mark B in forum VX Talk...
    Last Post: 09/09/2006, 10:44 AM
  3. oil change
    By etlsport in forum General Tips...
    Last Post: 06/30/2006, 12:19 PM
  4. oil change
    By RobVX in forum VX Troubleshooting...
    Last Post: 03/12/2003, 01:55 PM
