Results 1 to 12 of 12
Thread: Oil Change
    Hmm, Advance must run different ads in different regions because our local stores are currently running a "Any 5 qts Mobile 1 + Filter: $30" special through the end of November.
    You must have bought it used then. Merc generally only continues to honor warranties if THEY do all the maintenance. They are QUICK to deny you future obligations if you so much as put air in a tire yourself.
    Apr 2006
    2000 dragon green 0496
    Yes, car was used and has about 35k.
    Oil filter was $ 15.00.
    I did not see any deals on the mobile 1 when I purchased the oil.
    Yeah, it's crazy, my wife's 911 take like 10 or 12 quarts as well. But then again, at the rate my VX burns oil, I guess my little Isuzu is a bigger hog!
    Yes, Wally World usually has the 5 quart Mobile-1 jug for around $24-$26 in my neck of the woods.
    i had a lady come in to my shop a couple months back with an '06 taurus she walks in and tells me she needs her 30k service, when i asked her what type of oil she typically has put in (synthetic, blend, standard) she says well this is the first oil change so i dont know what they put in from the factory.. i say huuuuuh??? turns out she thought oil changes were every 30... instead of every 3.. sure enough it had the factory ford oil filter and everything.. that oil was BLACK
    did you advise her to start saving now for a new motor?
    Aug 2005
    1999, silver, 0887
    Okay, I'll say this again inspite of what others have said against this method (Tone, included. God rest his soul.) I have found the problem with the VX engine oil usage has alot to do with the filler cover "O" ring and PCV valve. Specifically, change that "O" ring every oil change and screw the cover down tight using a pliers, and second only use the Purolator PV 1061 valve, it's superior in every way. With these adjustments oil consumption declines, as less oil is blown into the engine intake system. I know this sounds too good to be true, but try it, it works. We've applied this metod with our two '99's with good success.
  1. Oil change
    By Mihai in forum VX Troubleshooting...
    Last Post: 07/01/2009, 03:10 AM
  2. Oil Change
    By Mark B in forum VX Talk...
    Last Post: 09/09/2006, 10:44 AM
  3. oil change
    By etlsport in forum General Tips...
    Last Post: 06/30/2006, 12:19 PM
  4. oil change
    By RobVX in forum VX Troubleshooting...
    Last Post: 03/12/2003, 01:55 PM
