"Sometime Early, Never Late, But Always On Time"
Looks good, Could even perhaps be mistaken for a manual.
did the old auto thing just screw off and that gear knob slide on ? whats happened to the lock thing so it cant be pushed into reverse from N without pushing the button
I like the looks of that. Reminds me of the old slap stick shifters in Buicks.
Can you upload it to your gallery on this site instead? PostImage is blocked by work.![]()
Yes the old shift knob did just screw off and the new one slid on
I have it set up so all you do is push down on the knob to get it to shift out of gear I'm sure thats the way etlsport has his set up
The boot I used was the factory boot from the 4X4 side and I just set it over the automatic plate
arent you afraid that someone else is going to drive your car and get confused?
You said a mouthfull...
I let someone else drive the hotrod once.............................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. ....................................just once...![]()
I like it. I never use the gear location stuff at the base of the shifter. I take that back, I do use it to hold my remote for the radio.
yep.. lol i work at a tire shop.. so im always the one to put it on the lift
