This weekend, I finally pulled the VX into the garage to fix my exhaust leak. OK, more accuratley, it leaked for a while and the the exhaust pipe finally fell off the manifold and rested on the crossmember... then I pulled it into the garage.It took me so long to get to it because I couldn't find the leak. I knew about where it was but couldn't tell if it was the driver's manifold or the pipe. Turns out it was the driver's side pipe. Just short of the weld seam on the down tube of the exhaust pipe, a crack developed. The crack continued growing over the last several weeks until it finally wrapped around the entire circumference of the pipe and let go.
Removing the exhaust is exhausting. I had to use a grinder on the exhaust flange bolts and also a damaged-nut remover - doing crunches the whole time. The O2 sensors are really in there tight also but I managed to remove them without damage with an adjustable wrench, extender bar, and patience - and a shoulder workout. (Having a new set of tools is awesome by the way!) Then I had to remove the trans crossmember to drop the center section of exhaust tubing along with the driver's caty. It took hours on Saturday to get thru the removal phase.
Sunday was all about the reinstallation. Luckily, there was a clean break at the weld seam so I could line up the two pieces perfectly. The repair weld was the easiest part of the whole operation and only took 1/2 hour! New gaskets and bolts, and I was ready to put it all back together. Not easy, but not really difficult either, it proved to be a one-man operation. Another work out again though!
I can't tell you how good it felt to get this repair done - I have been so out of ambition to do anything for awhile and this was a great launching platform to get me back into 'real mechanicing'! Even better is driving the VX again! It sounds good once more and has better pick up, like before.
Knivx, I'm getting it closer to trail ready for a run with you guys. Let me know when the next journey is scheduled for... besides next weekend. Time to get our VX Meet under way, me thinks!![]()
