riff is correct...(god i hate saying that
although, with a mild lift (1-2") you would almost never have problems with your CV axles... there are many of us here that have lifted almost 3" for years with no problems.
nice wheels by the way
 very similar to my new ones, but i couldnt afford the ones with the simulated bead lock.
ps, if you do lift...... use a different size spring instead of the spacer-
most vehicles work fine with a spacer, but the VX's springs are not 'bolted' onto the vehicle, they are just held in there with pressure, so there is a slight chance that your spring could come out with adding the spacer. whereas, if you add the OME springs you wont ever have that problem unless you also change the shocks to a longer application
