I am about to drop my truck off to get timing belt/water pump and all the other stuff that goes with it.....this has been about the only time I have taken either VX into a shop.....not nearly as upset as I was with the first VX. Anyway, while I was changing my oil filter this weekend, looking up from underneath I noticed coolant hanging on a bolt...not enough to pool on the ground or even drip enough to tell.....anyway, I freaked and decided water pump and while doing water pump since mileage says timing belt I am doing it all.....question is I JUST changed the oil sunday....do yall think I should change it again after having this done? Dont laugh.......
