Results 1 to 13 of 13
Thread: Missing Fob, need to change battery
    2001, Black, VX, too lazy
    My VX has been garaged for a couple of years, but now I need to start using it again. Problem is, I've misplaced the fob. I still have a factory key on my regular key-ring and it works to unlock the doors, etc.
    But the battery is dead and when I go to change it, the alarm goes off.
    Is there a way to turn the alarm off with just the factory key?
    Thanks
    I don't think there is.
    There is a procedure though for reprogramming the alarm system for several different modes. I'll have to look it up in the manual tonight (it's something like having your key turned to the ACC position, turning on your left turn signal, then opening and closing your door 3 times within 10 seconds). I'll try to scan that section & post for you.
    Is that the regular owners manual that is black and green?
    I think I still have my copy.
    IIRC, there is a seperate manual for the security system. I'll let you know.
    2000, Ebony, VX, 0370
    Thanked: 12
    I've set my factory alarm off by accident a couple of time (opened the door without disarming) and I've been able to just put the key in the ignition and either turn it to run or start the VX and the alarm has stopped. Maybe give that a try? Put the new battery in then start the VX while the alarm is going and it should stop.
    Sorry Steve - I didn't getr done last night. I arrived home to a minor emergency & it completely slipped my mind.
    One of our golden retrievers decided to go for a swim in the pool & couldn't get back out & almost drowned. She prolly ripped a hole in the liner which really pissed me off since I've been battling that problem for a year now (from the last time she did the same thing).
    Anyway, hope to look it up tonight.
    Thanks. That worked. It was also mentioned in the manual that Mark pointed out.
    BTW, if you haven't read the alarm manual yet, it is totally worth it. I always wanted my VX to automatically lock itself after I got out and it turns out you can set the alarm to do that. Now I just need to buy a replacement fob so I can use the alarm. There are a handful on ebay with wildly different prices - does anyone have a recommendation?
  1. MIssing bushing?
    By ron234 in forum VX Troubleshooting...
    Last Post: 06/03/2015, 10:08 AM
  2. What am I missing?
    By ahdoman in forum VX Talk...
    Last Post: 11/17/2014, 10:38 AM
  3. missing fang
    By zukicon in forum VX Talk...
    Last Post: 11/21/2011, 04:56 AM
  4. Am I missing something
    By Francesco Rizzo in forum VX Troubleshooting...
    Last Post: 02/25/2006, 09:54 PM
  5. Jet Li is missing....
    By Cyrk in forum VX Talk...
    Last Post: 12/31/2004, 11:09 AM
