					Hi flying77 !
Welcome aboard....
The head & tail light covers can be purchase @ summitracing.com (by GTS cover)
They sells both front & rear for little over $ 100.00 with shipping included
They got three kind of them
Smocked,clear & fiberglass.
Please be advised that due the rarity of our rigs the order may take up to two weeks after order had been placed because they don't produce them in mass quantities
However they would not charge your credit/debit card account 'till shipment is confirmed & on your way,but it's worth.
Check my photo gallery.
I want to warn you that if you go with either the fiberglass or smocked models you also want to purchase a set of high performance headlights bulbs such as Hella H4 with a output of 100/80 watts because the OEM light bulbs will project a very dimmed light beam at night.
If you do upgrade the bulbs  also replace both headlight OEM fuses (10 amps) with 15 amps fuses & you will be good to go.
				Dakar was just the begining.
