Results 1 to 9 of 9
Thread: HELP! Isuzu dealer service problems, timing belt, thermostat and more!
    Mar 2006
    Quote Originally Posted by elroyado View Post
    I need the opinions of you great vcross mechanics out there. Here's the story. My son's '99 vcross needed a new thermostat. I took it to an Isuzu dealer, they don't see many of these cars around here so I'm somewhat skepitcal - I said are you sure you mechanics can do this job because it involves removing the intake manifold etc. The said they could fix it. We picked up the car drove for at least 20 minutes and within a half mile of home the car makes a bad noise and stopes running. We suspect maybe it's the timing belt. ( By the way this was the second engine in the car and it only had about 40k on it).
    Towed it back and dealer said no compression, must be timing belt and engine ruined - said valves all bent. Well then I started to wonder about this and according to what I've read here this is a non-inferference engine. Like I said I don't think the dealer mechanics are familiar with the v-cross, I'm beginning to suspect that they just assumed the engine was ruined because they believe it to be an interference engine.
    Could the engine be okay and simply need a timing belt? Is it possible that they screwed something up when they did the thermostat?
    Sorry, but 6VE1 is interference engine, though in most cases it is not. So it could bent valves, especially on high RPMs. Have a good mechanic who rebuilt at least dozen of 6VD1/6VE1 engines.
    1987 AMC Eagle: stock
    Thanked: 7
    Sent you a PM that might help.
    Anita
    2000 Ebony #263
    AnitaProtich.com
  1. Did I screw up my timing? Timing belt replacement
    By workmeistr in forum VX Troubleshooting...
    Last Post: 04/13/2015, 07:26 AM
  2. Replies: 14
    Last Post: 01/07/2015, 05:21 PM
  3. Timing Belt Problems
    By term117 in forum VX Troubleshooting...
    Last Post: 05/28/2012, 03:14 AM
  4. Timing belt service
    By VX-157 in forum VX Talk...
    Last Post: 05/22/2008, 03:37 PM
  5. Timing belt replacement and timing videos
    By deermagnet in forum Archives
    Last Post: 11/26/2007, 08:09 PM
