Front end was loose for a while, thought it was a wheel bearing but notice when i did a ball joint flip that they were dead, so i ordered a set for a UBS 25 Trooper which is the 92 - 98 3.2V6 they dont seam to be tapered in the same way, and when tight there is a small gap between the rubber of the ball joint and the top of the hub whrere it moun ts. These ones also have a grease nipple on the top but they seamed to fit ok, now 2 weeks on and the wheels are loose and theres a knocking on the front end over bumps etc and the things are loose again, i've re tightened the castle nut up but the movement seams to be between the ball and socket. These things are brand new and were totally tight when fitted.
Couldnt have got 2 faulty ball joints?? Any ideas?? the VX is lifted, would that put any greater stress on these parts?? Or did i not get the right ones??
this was the part http://www.milneroffroad.com/img/pro...ages/10726.jpg
on this page http://www.milneroffroad.com/categories.asp?cID=9981
