Thanks, Orion.
I just ordered one. I tried to find a flasher a year ago when I decided against adding more load resistors or replacing the ones I have. I did install resistors in-line with the tail lights, and I went too many ohms (6 ohm on each side, and I should have gone 3 ohm each?). Bottomline, I have hyper-flash Turn, but normal speed Hazard. I hope this flasher does the trick. Thanks again.
Will give it another try, then will let a knowledgeable tech at Alltech do the exchange, lest I loose it and subject my dash to crowbar mods.
