Rowhard wrote:
"Hello newthings. You just won't believe how good that insert I bought from you with the yellow casting looks on my Dragon Green. When we get a sunny day here, will PM some photo's to you. Actually, when color sanding, Sand with 1200 wet in one direction then 1500 wet at 90 degree till the 1200 sanding lines are gone. Can then do 2000 wet at 90 degrees till the 1500 is gone, then machine buff to a high gloss, decreasing the grit till there is no grit."
I'm interested to learn more specific sanding techniques used during the wetsanding process ... Long strokes or short strokes? (full length of the part?) Light pressure or elbow grease? Is the sanding done before and after clear coat? Oh, and i'm goin ebony like the rest...
I have a porter cable orbital polisher and can buff/polish when done.
I'd like to get to as close to "quality" short of plunking down major coin each time the thing fades, so willing to learn now.
Thanks to any of the DIY painters in the house that can offer advice.
Jeff
BXVXY2K
