 Originally Posted by
Triathlete
				Jack, I think that would look good if it covered the entire opening. Then mount the subs (2 10's?")at an angle (left top/right bottom).If you 'glass the back you would have the entire spare area for volume.
im strangly obsessed with things being symmectrical... so personally i wouldnt mount them angularly, but for some it might work better.
i was planning on building a box then foam insulating the rest of the cavity to increase resonance. i was just gonna use two low powered 10's to achieve more than a shallow mount 12...
and yes, it eventually would of had another peice that would go back from the top of what i have currently, to the window. and i was gonna mount the amp up top there... or maybe the air tank i purchased, and hide the compressor behind the box.
