Results 1 to 15 of 28
Thread: Any advise on glue for window fix + ball joint flip help
    CR,
    After 11-12 years, those plastic tabs are gonna be brittle. I would highly recommend using SBC's upgrade. I have a spare one at home. Want me to check on shipping cost?
    As far as adhesive: if you are reapplying the plastic tabs, I'd use PC-7 (I can't buy it local anymore so I need to see if it can be ordered on line) ... if you are installing the SBC brackets, I'd use black RTV since it's strong, adheres to glass & metal but can be reworked if necessary.
    CR,
    As far as adhesive: if you are reapplying the plastic tabs, I'd use PC-7 (I can't buy it local anymore so I need to see if it can be ordered on line ... if you are installing the SBC brackets, I'd use black RTV since it's strong, adheres to glass & metal but can be reworked if necessary.
    I can get PC-7 locally in any flavour you desire, (they have different formulas for hi-temp, steel, wood, etc) let me know if I can be of assistance...
    Thanks. I'll let you know. I also need to pick up some PC-11 to install the depth finder on my boat.
    I'll check what they have at my local fav hardware when I'm out & about later, & post a complete list of what they stock.
    The last time I was in there, I noticed they had an amazing selection of the "PC" line, along with a huge variety of other epoxies...
    As promised...
    PC Farenheit.(up to 500 deg)...1 oz. $5.00
    PC Lumber.(for wood.....duh)...1 oz. $6.00
    PC 11.............(Marine)..........2 oz. $6.00
    PC 7........(Multi use-general)..2 oz. $6.00
    PC Plumbing.....(guess)..........2 oz. $6.00
    PC Metal.........(again)...........2 oz. $6.00
    PC Crete.......(for concrete)....2 oz. $6.00
    97 Jap Import, Black BEAST
    CR,
    Thanks ! is that 1 set (both brackets) ? Ship to
    LONDON
    SW10 9EL
    I have a complete spare set (don't ask why). I'll check into postage.
  1. Ball Joint Flip - Did you do it? Why? Why Not?
    Last Post: 02/05/2016, 08:07 PM
  2. diff drop/ball joint flip
    By raver_boi_88 in forum VX Talk...
    Last Post: 06/19/2013, 09:36 AM
  3. Ball Joint Flip Problem
    By TEN36VX in forum VX Troubleshooting...
    Last Post: 06/09/2008, 07:35 AM
  4. HELP Ball joint flip problems VX on blocks!!!!!
    Last Post: 04/10/2008, 10:45 PM
  5. Purpose for ball-joint flip?
    By coachreed in forum VX Modifications...
    Last Post: 09/15/2003, 04:37 AM
