Results 1 to 7 of 7
Thread: Towing an Airstream
    Mar 2003
    1998 Blue standard 1198
    Towing an Airstream
    I am thinking of buying an Airstream caravan and want to tow it with my VX does anyone know what size I could tow as a maximum is a 28ft too much?
    Best regards
    David Wiltshire.
    Nov 2002
    Basically follow the specs on the Trooper RS, which is 5000lbs with 500 on the tongue max. Just keep in mind that the short wheelbase makes for different handling and to keep the auto out of overdrive. I haven't towed yet with the VX (haven't installed Tone's hitch yet) but did extensively with my '93 Trooper RS. Had absolutely no problems and actually enjoyed the extra maneuverability afforded by the shorter chassis. Especially with the bigger, heavier loads!
    Nov 2002
    OOPS!
    Thanks SPAZZ! Forgot about them dinky hitches!
    Anything over about 3K lbs should be equipped with trailer brakes. Then as long as it does not exceed the 5K total, 250lb tongue weight (for the VX) you should be fine. Not sure I would tow it through the Catskills though. Watch for the Tranny Overtemp light and I strongly recommend using synthetics if you are going to do this regularly.
    2000 Dragon Green VX 0485
    1: As a former Airstream owner I think they are way overpriced.
    2: Trailers towed by Short wheelbase vehicles tend to be unstable in high wind conditions.
    3: Here is a forum where you might pick up some useful info.
    http://www.airstreamforums.com/forum...?threadid=4657
    Mar 2003
    Towing an Airstream
    Thanks for all the replies if I do decide to get one I guess the 24 to 26ft range will be best. Next stage is to find a dealer to export one for me, to save transport costs I guess I need a dealer near the East coast anyone know of a good dealer?
    Nov 2002
    Lightbulb
    Why would you import? There's gobs of Airstreams in the UK. Just plonk the requisite search info into Yahoo! or Google and have at it.
  1. VX Towing
    By Vinnybin in forum VX Talk...
    Last Post: 02/22/2014, 05:45 PM
  2. Towing
    By skater in forum VX Modifications...
    Last Post: 05/08/2007, 10:55 AM
  3. Towing A Vx
    By eyepatch in forum VX Talk...
    Last Post: 10/27/2006, 09:23 AM
  4. Towing VX
    By bullsender in forum VX Talk...
    Last Post: 09/12/2006, 10:07 AM
  5. Towing on the VX
    By Snake in forum VX Talk...
    Last Post: 01/24/2003, 05:28 AM
