So now that the boy is here and my pockets are empty, I think I might need to replace the Mode Selector Switch.
Right now, the only problem is the flashing park/reverse/drive lights. Not all the time, just when I change gears. When I went from Reverse out of my driveway, then to neutral, then to drive, the light stayed on neutral for a second. I know that the problem can be intermittent and it can also get worse. So, I want to fix it before it becomes a bigger problem.
My question is .....
I am a smart man, but not a mechanic. Is this a job that I can do without the possibility of breaking anything? The last thing I want/need is to make the problem worse.
Also, I have read 2 different things regarding the Mode Selector Switch. One, replace. Two, Fix.
Fix: http://www.vehicross.info/forums/sho...elector+switch
What is everyones thoughts on those two questions?
To recap:
Question 1: Can I do this myself?
Question 2: Fix or replace?
Thanks all!!!
