Results 1 to 8 of 8
Thread: Power Door Locks Not Working
    Aug 2009
    2001 Ebony Black, VX, 0986
    When I push my power door lock button none of my door locks lock or unlock.
    Nor does my keyless entry unlock them. I checked the 20A Fuse which is good.
    Anybody ever have this problem and can advise?
    Aug 2009
    I found the problem!!! From another thread years ago!! Thanks.
    Hotsauce09/29/2003, 04:04 PM
    This happens when the connector to either door switch gets loose.
    Grab the front edge of the panel holding the window switches, and swing it up. Unplug the connector to the switch, and reconnect it, this should solve this.
    John C.
    Oct 2008
    UK Sunburst Ltd 000/175
    This also happened to me but it was the standard 5 pin relay that puts 24v to the motors from the ignition switch that was faulty (cost me 3 quid replace). The relay is located behind a plastic panel in the driver's foot well (JDM right hand drive)
    May 2002
    2000, Proton Yellow, VX, 0584
    Very good to see this go worked out! Very happy to see the site was useful! You just made my day!
    Scott / moncha.com
    1999,silver,vehicross,1891
    this just happened to my VX, been a hot day here in Cincinnati, fine when I left home, back an hour later and actually thought my battery went dead, lock system dead, gonna check fuses, relay and connections after sunset!
    that ended up being a half charged battery. While the car started up and ran normally, the battery wasn't fully charged cause I been using air conditioning alot killing the battery I guess
    my short distance daily drives with full AC power on definently using more power than my alternator can provide and charge, I just rotated a new battery into the car to see if it's a weak DieHArd Gold battery failing to take the charge
    Oct 2003
    2001, Foxfire VX,
    Cool
    Quote Originally Posted by Trap11 View Post
    John C.
    Trapp, your old post of Hotsauce's old post is still helping folks out. My '01 Foxfire's power door locks haven't worked for 3+ years... now they do! Thanks a bunch. - Brian
  1. door locks barely working
    By vxcp in forum VX Troubleshooting...
    Last Post: 06/18/2014, 07:14 PM
  2. Door locks Hmmmmmm
    By AlaskaVX in forum VX Troubleshooting...
    Last Post: 04/10/2011, 11:31 AM
  3. Door Locks
    By Offroad vx in forum VX Troubleshooting...
    Last Post: 11/07/2006, 11:47 AM
  4. Auto door locks & side mirrors
    By Mantronix7 in forum VX Talk...
    Last Post: 09/15/2005, 01:27 AM
  5. Power Locks acting weird
    By migil in forum VX Troubleshooting...
    Last Post: 10/12/2003, 05:06 PM
