So if i start out slow there is no problem, but if i get on the gas hard at take off then when the TOD first light up it jerks pretty darn hard, Anyone know what the problem could be and how to fix it.....
any guesses???
lots of power and lots of traction??
but really, it could just be your tod removing power for a split second from the rear wheels, then putting all the power to the front ones... mine actually feels like its chattering when i step on it hard, but its actually just because i have mud tires and the TOD gets confused
Ive been having he same prob, it makes such a racket that it really worries me. Dude at the shop told me to try turning my front locking hubs to 4x4 instead of 2x4, same problem. In 2x4 the front wheels shouldn't be getting ANY sudden torque, but it happens in both settings.
I do notice it happens less frequently when I turn the "Power Mode" button on. I'm still not sure what to make of it. It almost feels like the front wheels are "hopping" for a half a sec when I stomp on the gas from a dead stop.
I too am using mudders, Yokohama Geolanders that are getting pretty thin down the middle. I wonder if they actually DO hop a bit. But shouldn't happen at all if the locking hubs are in 2x4 cuz the fronts shouldnt be getting any power at all in 2x4 if I understand it correctly.
Anyone wanna correct my assumptions?
exactly my problem grif. it does happen less in power mode. If you gun if off the line it get's like full all wheel drive, and the three lights one the TOD display light up for each front wheel, the car jerks real hard then drops to just one light on each wheel and off you go. It happens every time i stop. if i give it just a little gas it lights the first lights up and i'm off to the races with no issue after that until the next full stop.
Dunno but you should try to set the TOD on 25/75 instead of the 50/50.
Plus that set up provide you bit more of MPG.
Dakar was just the begining.
i just got it like a week ago, how do i "set it up" to 25/75. and grif is havin the same problem
sounds like the electromagnetic clutch in the transpher case is faulty? i dont know if it has any friction plates that could wear out?? Worth looking through the manual to see if there are any service parts.
Put it in low ratio and give it some stick off the line, if it does the same things its not the clutch. (when in low ratio the electromagnetic is bypassed by a drive chain) if it still does it maybe its some slack in the tranny?
You'll have to start iliminating variouse parts of the drive train to find the fault
To clarify my prob, I gun the accelerator, the TOD lights for the front jump up for half a sec as the "hopping" occurs, then they go back to the normal 25/75 front/rear indications. (Or rather 25/100 as indicated by the lights, which AFAIK is normal, even tho the actual power distribution is 25/75)
I am unaware of way to "set the TOD on 25/75" because as far as I know 25/100 is what I should be seeing under normal conditions anyway as long as I'm in 4 wheel high. Honestly, Ive never even run it in 4 wheel low which SHOULD set to TOD to 50/50.
And to re-iterate, I still have the problem when I unlock my fronts with the manual hub lockers set at 2x4, which should stop the front wheels from getting power at all. (tho the TOD system will still report 25/75 or actually 25/100 to be exact. In my understanding normal operation of the TOD indicators while in 4 high should be 100% of the rear lights and 25% of the front under normal dry pavement conditions)
Is that correct?
Previper: I'm not trying to hijack your thread here, but it does sound like we have the same or similar problems and I too have only had my VX for a couple months, so I'm not sure whats going on with it jerking like that when we accel from the line.
Grif no problem, you aren't hijacking you do have the same problem, and the more people the pop in and say they do, the more importance it puts on the subject and the more likely someone will figure it out.
[quote=Grif;170909]To clarify my prob, I gun the accelerator, the TOD lights for the front jump up for half a sec as the "hopping" occurs, then they go back to the normal 25/75 front/rear indications. (Or rather 25/100 as indicated by the lights, which AFAIK is normal, even tho the actual power distribution is 25/75)
Ok. whenever you turn on the VX the TOD only lights up the rear three bars,as soon you speedo hits 7-10 MPH the front lights goes on.
If you have the TOD in 50/50 or better say 100/100 mod all three front lights will turn on,my horse only lights one @ the front.I may say as well you do 25/100 which is right so sorry for the mistake.
Anyway,having the TOD in 25/100 allows you to decrease the wear of the front drivetrain & provides you more MPG as i said before.
Crotch's troubleshooting prob can provide you more detail & lead you to pinpoint where's the source of the issue.
Check the trans & x-case fluids level to make sure they are within manufacturers specs.
You may also need to flush & refill the differentials.remember the rear diff need enough LSD additive to work properly.
Hope our help can ease the issue or even solve it![]()
It has 75000 miles on it at 68000 before i owned it it had a full service done with a flush of the tranny, transfer case, and both diffs. but that's not to say they replaced the fluids with the correct ones.
I don't think that the TOD indicators are necessarily a good indicator of the health of your transfer case.
Start with the simple and work upward.
Drain & refill the rear diff with a good synthetic & make sure it has the LSD additive or you add it. I know you indicated it was recently done but ...
While you're doing that, check the panhard rod to make sure that there isn't any wear in the mounts at either end.
Next check your tranny mounts. If they are loose or worn, it can cause all kinds of strange symptoms.
This weekend i'm going to do both diffs, the transfer case and transmission with filter. tom i sent a pm let me know when you are in town and you can come check her out.
OK i checked out the trans mount, looks good, the rubber was all in tact and no real deterioration. I'm still looking at changing the fluids this weekend. any other suggestions?
