Page 3 of 3 FirstFirst 1 2 3
Results 31 to 42 of 42
Thread: Need new lift and have $1000 to spend
  1. #31
    viper,
    I can't say how much was spent on my lift since it was done by the previous owner. I do know that he used the Calmini kit which is $$$ but then turned around and removed all of the kit from the front & just did the torsion bar crank. It sounds like you've pretty much made up your mind to go with the kit. Go with your gut feeling & enjoy the results.
    On the diff drop issue & 'eating' CV boots. Some get away with it - some don't. I went through 3 sets of boots in 1 year (& toasted the CVs once), LittleBeast was just as bad, Bart's been lucky & hasn't had any problems. Do your lift & wait to see if you need the drops. There are still pix in my gallery of the ones I had done.
    Dub,
    I didn't notice any significant loss in ground clearance with the diff drop. Technically speaking, you're right. In reality, the pumpkin doesn't hang down any more than any number of things down there (crossmembers, oil pans, ...). My dropped Calmini crossmember may be a problem for me if I make it to Moab 2010.
    Peanut Butter,
    Yes, guilty of TJ but ... it was still within the general scope of the thread & since viper is a newbie, he needs to be educated on what offset from hell looks like. I was really just tempting him to go look in my gallery for a look that is slightly more radical than what he's currently entertaining.
  2. #32
    Aug 2009
    2000, white
    I'm set on wheel size and tire size wheel 16 x 8 and tire 285/75/16 all terrain now what offset should I look at?
  3. #33
    Quote Originally Posted by previper View Post
    Generally speaking, unless you want Tom's "offset from hell", go with the wheel in any given brand/model with the greatest amount of backspacing.
    Try to get a wheel with + offset value (more backspacing) with zero offset as a minimum.
  4. #34
    Prices?
    For the springs the cheapest will be Rocky Road...he doesn't always keep them in stock so it may take a little longer to get them. If you want them fast...Indy 4x
    As for shocks and spacers...search the web and ebay for best price. For speed and in stock...Indy 4x
    Indy 4x also will give you GREAT customer service, assistance and advice. His kits are thoroughly put together and usually come with everything needed (except tools). You can call Matt with any problems and he is always eager to help you resolve it.
  6. #36
    Aug 2009
    2000, white
    sounds good people, i appreciate the help, i think i'm going to go with +10 offset, now time to find some black wheels, any favorites out there?
  7. #37
    Nov 2002
    2001 Dragon #0467
    the spacers are 100 for the pair.
    If you need spacers try these instead, they work the same as those $90 1in. Indys.
    I tested them here
    Daystar KC09103BK
    This Daystar spacer works well as a 1in. spacer on the OME Springs.
    $38 shipped, no tax
    at amazon.com
    rickshaw
    2001 Dragon #0467
  8. #38
    Jul 2009
    2000 silver 0742 and 2000 firefox 0758
    do they make a Daystar 2" poly spacer for the VX springs at that price too? if so, what part number?
  9. #39
    May 2002
    2000, Proton Yellow, VX, 0584
    Take a look at Ebay
    Scott / moncha.com
  10. #40
    Aug 2009
    2000, white
    http://raleigh.craigslist.org/pts/1349449291.html
    what's the consensus on these, I wanted black wheels pretty bad so if i got these i'd probably just paint them.
  11. #41
    Jun 2007
    2001, Proton
    Talking my opinion is
    posting this in one thread is probably enough
  12. #42
    Aug 2009
    2000, white
    i first posted here but figured i wouldn't get everyone's opinion so i made a forum just for them and i'm glad i did i got some good input.
  1. Replies: 95
    Last Post: 01/08/2016, 11:59 AM
  2. Line X, or Rhino Lined Cladding... How much did you spend?
    By taylorRichie in forum General Tips...
    Last Post: 10/16/2010, 01:07 PM
  3. 2008 Baja 1000
    By MoonRaker in forum VX Talk...
    Last Post: 03/30/2008, 06:57 PM
  4. PIAA 1000 Lights HOT SALE
    By VXMAN in forum VX Modifications...
    Last Post: 03/18/2005, 06:21 AM
